Question about bryton Rider 20 E GPS Cycle Computer | Cycle Computers
Reset odometer rider 20 bryton - bryton Rider 20 E GPS Cycle Computer | Cycle Computers
The device recovery tool downloadable from the Bryton website will fully reset the device including Odometer
Posted on Oct 03, 2014
Ineed to logout Bryton McClinton email to login michellehicks email how do I do that
Bryton needs to log out of his email account. Then Michelle needs to login.
Feb 04, 2017 | Computers & Internet
Reset inspection due message on vauxhall astra
Leave the key off. Press and hold the reset button,( it's to the rt. of the odometer). Turn the key on and press on the brake, (While holding the reset in). It should reset in 10-20 seconds.
Nov 07, 2014 | Vauxhall Cars & Trucks
1999 flhr road king shock air pressure
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
SHOCK LOAD TOTAL WEIGHT PRESSURE
LB. KGPSI kPa
Solo rider up to 150 up to 680 0
150-200 68-91 0-10 0-69
200-250 91-113 10-20 69-138
250-300 113-136 20-30 138-206
over 300over 136 30-50 206-345
Solo rider with capacity
luggage of 40 lbs (18 kg) up to 150 up to 68 10-20 69-138
150-200 68-91 20-30 138-206
200-250 91-113 30-40 206-276
250-300 113-136 40-50 276-345
over 300 over 136 50 345
Rider plus passenger ALL ALL 40-50 276-345
Maximum GVWR ALL ALL 50 345
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
May 13, 2014 | Harley Davidson FLHR Road king Motorcycles
What is the air pressure for shocks on a 97 flhtc
I do not know but you could call a Harley Service department or better go there in person and ask.
Solo rider up to 150 LB up to 68KG10-20 0 psi0kPa
Solo rider up to 150-200 LBup to 68-91 KG0-10 psi0-69kPa
Solo rider up to 200-250LBup to 91-113KG10-20 psi69-138kPa
Solo rider up to 250-300LBup to 113-136 KG20-30 psi138-206kPa
Solo rider up to over 300LBup toover 136KG30-50 psi206-345kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150LB up to 68KG 10-20 psi 69-138kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 150-200 LB up to 68-91 KG 20-30 psi 138-206kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 200-250 LB up to 91-113KG 30-40 psi 206-276kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to 250-300LB up to 113-136 40-50 psi 276-345 kPa
Solo rider with capacity luggage of 40 lbs (18 kg) up to over 300LB up to over 136KG 50 psi 345 kPa
Rider plus passenger ALLWeights 40-50psi 276-345 kPa
Maximum GVWR ALL Weights 50psi 345 kPa
Apr 17, 2014 | 2001 Harley Davidson FLHT Electra Glide...
Bryton rider 20
This has to be at the sensors. Adjust them closer until you get a reading. May need spacers to get closer.
Apr 13, 2014 | bryton Rider 20 E GPS Cycle Computer |...
2007 dyna glide low rider with 4000 miles .. I was riding for a hour then stopped and fueled with gas then rode 20 mins more and it just lost power and wouldn't start
Any error codes?
1- Turn Ignition switch to OFF, Run/Stop switch is to Run.
2- Push odometer reset button in and hold.
3- Turn ignition switch to Ignition and release odometer reset button.
Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. If there are codes present, push the odometer reset button again to view additional codes if they
exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer
Feb 21, 2014 | Harley Davidson Motorcycles
Odometer stopped working
How many miles are on this vehicle? I ask because the odometers in these car stop working around the 140k to 170k mark. Did the button comeback? Is this the mileage on the digital or analog trip meter?
The process to change the odometer gear is fairly straight forward and takes less than $20 and an hour. Let me know.
Dec 11, 2011 | 1994 Volvo 850
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
bryton Rider 20 E GPS Cycle Computer | Cycle Computers Logo
575 people viewed this question
Top bryton Cycling Experts
Jerry Kramer
Jerry Kramer
Donald Ayers-Marsh
Are you a bryton Cycling Expert? Answer questions, earn points and help others
