Question about Lionel New York Central Flyer
Wheels sparking when in operation - Lionel New York Central Flyer
I put a flint and fluid in my old Ronson lighter, and it STILL won't spark.
Hey Vicki, Did you remove all pieces of the old flint?? it needs to be clean.. The spark wheel must make good contact..(could the spark wheel be worn out??)..Some spark wheels have the carbide only on the edges as rings that do the sparking.. some very high end lighters have a solid carbide wheel..$$... make sure the sparking wheel is making good contact..(you may have to stretch the spring that pushes up on the flint..just a little... good luck..
Jul 17, 2017 | Cars & Trucks
Model WD-65734. Why is there no picture?
Never heard of a color wheel needing to be replaced. Both cooling fans need to be clean and turn easily. Color wheel fan needs to turn easily. If any one of these motors does not turn, the controller will cause a shut-down. The Xenon lamp uses high voltage to operate. If the power supply was damaged, the lamp won't light. The sparking on the ballast board indicates that dirt or dust may be causing the problem. Also, the clamping diodes and regulator may be defective. If possible, try replacing the lamp power board. Regards.
Dec 22, 2015 | Mitsubishi WD Televison & Video
How do i remove the steering wheel with cruise control and airbag?
This is a semi difficult task. There is a "clock spring" in the steering column that allows for operation of the controls on the steering while turning. There is also an airbag connection that if disconnected and a spark (static) should occur the airbag could go off and cause severe injury. There is also specialized steering wheel pullers needed. If you have never performed this it would be best to have a professional do it.
Aug 19, 2015 | 2001 Mazda Tribute
No spark
The spark generator that sits close to the fly wheel only needs a mm gap. Make sure that this is the case. If there is a small gap there is possibly a break in the wire or the points under the fly wheel may also be rusty.
Jun 29, 2013 | Garden
What is traction control sistem
TRACTION CONTROL: An enhancement of an existing ABS system that prevents wheel spin while accelerating on wet or slick surfaces. It uses the same wheel speed sensors to monitor wheel speed during acceleration, but requires some additional control solenoids and a pump to apply braking pressure to control wheel spin. The traction control system brakes the drive wheel that's starting to spin to shift torque to the opposite drive wheel that still has traction. Most traction control systems only operate at speeds up to about 30 mph. Additional control strategies that some traction control systems use to limit wheel spin include reducing the throttle opening, upshifting the transmission, retarding spark timing and deactivating fuel injectors.
Hope helps.
Dec 23, 2010 | 1996 Acura RL
Poulan pro 625 series Will not start. I have changed the spark plug. Tested the plug for spark (yes) Checked the primer- works , sprayed starting fluid in spark plug hole and intake -nothing. it act like...
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Apr 17, 2010 | Poulan Pro 22" Self Propelled High Wheel...
What maintenance is scheduled for 60K
 STEERING/FRONT SUSPENSION: CHECK
• Maintains integrity of steering and suspension components, and
assures proper wear
 REAR SUSPENSION: CHECK FOR WEAR
• Maintains integrity of suspension components, and assures
proper wear
 DRIVESHAFT JOINTS: CHECK FOR WEAR/PLAY
 DRIVESHAFT: CHECK BOOTS
• Assures proper wear and that foreign matter does not contaminate
drive shaft joints
 PROPELLER SHAFT, PILOT BEARING AND
UNIVERSAL JOINTS: CHECK WEAR
AWD models only
• Helps assure proper all wheel drive performance
 EXHAUST SYSTEM: CHECK FOR DAMAGE/LEAKS
• Maintains quiet operation and proper emission control
 SPARK PLUGS: REPLACE
Except engine VIN code 85
• New spark plugs are specially designed and calibrated to provide
optimum engine operation.
• Engine is tested on special Volvo equipment after spark plug installation
Mar 25, 2010 | 2004 Volvo S40
Spark on the belt wheel
check motor mounts engine may be moving close enough to cause a spark
Dec 22, 2008 | 2002 Kia Spectra
Maintenance
OFF-ROAD VEHICLES - Initial Service: Check carburetor adjustment, engine idling speed and starter operation/adjust if necessary, Change engine oil/filter, Check clutch operation, Check wheel runout, spoke tightness and for damage, Check swingarm pivoting point for play, correct if necessary, Check steering bearings for play and steering for roughness, Check sidestand Torque all nuts, bolts and screws to spec, Clean or replace air filter, Check tires for damage, Check front and rear brake operation, fluid levels and for leakage, Check wear levels on brake pads, Check and adjust chain/sprockets, Road Test Motorcycle. EVERY 60 HOURS: Check fuel hoses for cracks or damage, Check spark plug condition. Clean, gap or replace if necessary, Check exhaust system for leakage, Check wheel bearings for looseness or damage, Check fork and shock for leakage or damage and smooth operation, Check battery terminals for looseness and corrosion. EVERY 120 HOURS: Check valve clearances, Clean spark arrester, Repack swingarm bearings, Replace fork oil, Replace brake fluid
Nov 10, 2008 | 2005 Yamaha WR 250 F
Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Aug 27, 2008 | Clarke Power Products Cast Iron Bench...
Lionel New York Central Flyer Logo
24 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
