Motor working but doesn't blow air from the outlet
    Master:
  • 571 Answers
Set screw, or clip, or fan hub wallered out. Make sure blower wheel is properly connected to motor.
Posted on Jan 06, 2014
My Air cond, heat and vent doesn't work at all on my car. I have replaced fuses and the blower motor. Whenever I put the new motor in it would run then blow the fuses. Could it be the compressor?
No, the compressor will NOT cause these fuses to blow. You have a SHORT in your electrical system. you have a HOT wire getting into the Ground for that system
Apr 09, 2013 | 2002 Mercury Sable
Air doesn't blow out of heater/ac vents
There is a possibility that the fan may have came off The motor shaft/spindle which has to rotate to blow the air to the vents
Oct 16, 2012 | 1995 Honda Accord
The a/c in my car doesn't work
The system will need to be recharged with freon and if there is no air flow in the front then there may be a stuck vent flap that won't move or a faulty motor that moves the flap.
Jun 06, 2012 | 2006 Honda Odyssey
Air Conditioner fan problem. AC fan very noisy and doesn't blow with full power
bushing in motor is probably shot,or some critter put it's nest in there ,either way the motor has to come out.
Jan 11, 2012 | 2003 Chevrolet Malibu
My tub motor does not come on when i press the air switch to turn it on. I did not see any leaks in the tubing, and there is power to the GFI outlet. The system hasn't much use so i do not think that...
Either the button is bad or the air switch in the back of the motor is bad. Blow into the switch on the back of the motor and if it comes on then you know the button on the tub is bad. If it doesn't come on then you know it is that switch.
US Parts Center
Aug 31, 2011 | Jacuzzi - Whirlpool - Corner - Gallery...
I just bought a 2001 Ford taurus. The heater works, but will only blow air through the defroster and floor outlets. It will not blow air through the vents on the dash panel.
it sounds like it could be a problem with the vacuum motor it could also be a vacuum line or the switch. I would check the vacuum motor first when you check the vacuum motor you should also be able to see if there is vacuum in the line. if there is no vacuum in the line I would check the switch next.
May 12, 2011 | 2001 Ford Taurus
I filled the tub, pushed the start button and all worked just right. When I went to shut it off it wouldn't shut off. I tried repeatedly. Finally had to get out of the tub and unplug it, (couldn't find any...
Sounds like either the air button on the side of the tub has quit working or the air switch in the back of the motor is not working.
Take the pump out. Get a straw, plug the pump into a working power outlet, blow into the straw into the air switch (where the air tubing was connected) on the motor. If the pump comes on/off when blowing into the straw then the air button on the tub is bad. If the pump will not come on or turn off when blowing into the air switch with the straw then the Air Switch is bad.
Jan 08, 2011 | Whirlpool Home
This 2000 le sabre has a seperate control for the passenger to adjust temperature. the passenger side blows cold through the dash outlets . the drivers side blows uncooled air.is there an air door thats...
There is a door actuator motor not working,the dash has to be removed to access the actuator motor,if this was helpful,at all,please rate,thank you.
Jul 20, 2010 | 2000 Buick LeSabre
Unit lights up and hums but does not blow air
mcdevito75 here, Sounds like the fan motor is haging up or needs to be replaced, try the switch on/off then on/off a few times see if the fan kicks on, if not see your local a/c repair shop, they come to the house.
Jun 22, 2010 | Whirlpool ACQ158XP Wall/Window Air...
Blower on heat/a not working
So it works with a/c but doesn/t work with heat. Is that what your saying?
Or it blows cold air on heat selection?
If it blows but only blows cold air on heat selection
check out the following items:
temperature selector switch
blend door actuator and motor.
Here are a list of items to check out or have a shop inspect if it doesn't blow anything at all.
a) on/off switch
b) relay
c wiring
d) resistors
e) blower motor
May 11, 2010 | 2004 Chevrolet Colorado
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
