My ducted airconditioner doesn't blow cool air but motors is working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
You need to get it gassed.There must be a leak of gas somewhere along the copper lines or joints.
Posted on Jan 05, 2014
22yooper
  • 828 Answers
SOURCE: My blower motor doesn't blow air out the air ducts why
Check for a frozen cooling coil. Turn the fan to the on position at the thermostat and the cooling to off. Your cooling coil may be iced over. Allow it to run in the fan only mode until the coil has had a chance to defrost. At the outside unit you may see the large line is frosted. This is the visual indication for a frozen coil. When you return the A/C to cooling use it with the fan on while in the cooling mode.
Posted on May 27, 2008
bobotfel
  • 236 Answers
SOURCE: Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Posted on Jan 08, 2009
louislevel_2
  • 374 Answers
SOURCE: Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Posted on Mar 13, 2009
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
  • 257 Answers
SOURCE: Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
Posted on Sep 02, 2009
My portable airconditioner,dimplex dac 3400, the cool function is exactly like the fan function, It doesn't blow cold air??? Do u ever need to regas this machine at any time???
Check the condensor coil to see if it is stopped up. The duct that you run outside to vent the heat that is being removed is attached to it. Does that duct move air at all or a good amount of air?? If coil is stopped up it will restrict air. Is the compressor running? If the coil is stopped up it is likely to overheat the compressor or the compressor start components may of failed. See if you can tell if it is running. It could be a bad compressor. Typically small systems issues do not have problems with freon leaks and you should never have to add freon unless you have a leak. Is there a filter on it check to see if it is stopped up. If it has ran with a dirty filter check the cold evaporator coil to see if it is stopped up. I haven't see. That exact machine but these are basic things to look for.
Dec 10, 2015 | Heating & Cooling
Rv airconditioner trips breaker
Does it trip when fan only , or when compressor for cool cuts in? Sounds like capacitor perhaps . Get back to me with model number, and whether it's a ducted system, or blows out at ceiling assembly.
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
It doesn't take the humidity out of the air. It alsocausesdampness in the air and cloth furniture, etc. When I first bought the airconditioner it removed the humiidity and cooled my apartment just fine...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 27, 2011 | Kenmore 76081 Wall/Window Air Conditioner
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Cool air not coming out if air conditioner but all else works. Fan on outside equip works , air through ducts. Thermometer temp stays same. Water comes out of drip pipes .
heatman101
Jul 05, 2011 | Carrier Heating & Cooling
My air conditioner just stop working it makes noise but it doesn't cool and the motor does not spin around what is wrong with it?
heatman101
Jul 02, 2011 | Heating & Cooling
Our model is the ART30RLA ducted airconditioner and we are having problems with it. The problem is that it will not cool down, everything is running but it won't get cool. Could you please help us with...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | Fujitsu Heating & Cooling
Our reverse cycle airconditioner is not cooling in two of our bedrooms, but the rest of the house seems to be cooling alright, but I am sorry the airconditioner is approximately 6-7 years old and we have...
Hi, I assume it is ducted, it could be either a flapper door is closed to shut off an area from receiving air, or there is a blockage in the duct (less likely). Also if there is more than one duct attached to the air conditioner then you'll have to check if air is entering all ducts (you may have a problem with the unit).
Nov 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
