Question about Dell Vostro 1310 Notebook
Card reader not working - Dell Vostro 1310 Notebook
    Top Expert:
  • Dell Master
  • 22,161 Answers
Is the driver installed?
Posted on Jan 04, 2014
Computer is not seeing verbatim usb 3.0 card reader
Try a different usb port on your computer. If you using ones on the front, try the ones in the back. If that doesn't work, try the reader on a different computer. If the reader doesn't work it is most likely defective. A pretty common occurance with usb card readers in general.
Also try putting a card in the card reader before inserting it into the computer, not while it is plugged in.
Good luck
Dec 07, 2013 | Verbatim USB 3.0 Universal Card Reader -...
Why is my memory card reader not reading memory card?
What type and size memory card? What card reader? Is the card reader compatible with it? For example, SDHC cards will fit into an SD card reader, but unless the reader was designed specifically to be compatible with SDHC cards as well as SD cards, it won't work.
Jan 09, 2013 | Cameras
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
My laptop does not read the memory card when i put the memory card in the card reader slot
There might be some technical problem.It can be with the card reader slot probably.Try using the memory card on another card reader if it works replace your card reader as it is faulty.Also do check that none of the cables connecting the card reader to the p.c are defaced/damaged.Do make a note that the Port on which you are using the card reader is working properly when you attach some other device to it.If still your card does not work then your card is faulty reaplace it with a new one
Dec 15, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I put a sd memory card from my camera in my computer. the computer hasnt uploaded the pictures or done anything.
I guess you have a built in card reader? Is there any chance your camera SD card is SDHC? Some card readers including built in types and those that you connect to a USB port have trouble with the later and faster generation SDHC cards but are happy with plain old SD cards.
If you are using an external card reader, does it work in another computer? If it does work, then the problem is with your computer.
If you have a built in reader, can you borrow someones external card reader that you know and does work with SD and SDHC cards?
Can you try an older SD card in your current setup? If that works OK then it's the issue with SDHC that is your problem.
Easily fixed by buying yourself a $10-20 external card reader
Cheers,
Steve
Aug 11, 2010 | Computers & Internet
Centros Secure Digital Card Reader Model No.4418951 will not read a SanDisk SDHC Card 4GB.
1. Safely remove the Card and Card Reader from your system.
2. Plug in the Card Reader to the system.
3. Now, insert the Card in the reader.
4. Let the system take some time to detect the devices.
* If the Card Reader donot read the card, try another card to check if there is problem with the reader or card!
* If the Card Reader still donot detect, check it with another system.
tell me if it works...tc! :)
Dec 31, 2009 | Computers & Internet
We have an Hp computer. The memory reader in the
Hi Larry,
There are a few likely scenarios that would cause your card reader not to work.
1. The cable inside the computer that connects the front-panel card reader to the motherboard has come loose. You can check inside the case to make sure the cable is tight and connected. You should do this with the computer turned off, and turn it on when you're done.
2. The card reader itself has gone bad and stopped working. If this is the case, you'll need to either contact the manufacturer for repair, or you can go out and get yourself an external USB card reader for cheap.
3. The card reader is functional, but there's something wrong in the operating system that prevents the cards from being read, because the operating system doesn't know how to address the card reader. This can usually be fixed by re-installing drivers and software for the card reader.
May 18, 2009 | HP Pavilion a705w PC Desktop
Card reader stopped working
go to the pavillion website and download drivers for the card reader (you can find the correct drivers by searching the model or serial number to your machine). install the drivers for the card reader (they prolly dont take drivers, but try anyway) the card reader is most likely defective, or the ide ribbon cable came loose from the back of it.
Dec 24, 2008 | Computers & Internet
Memory card
try to have the phone memory card formatted then try again.
Jun 04, 2008 | Samsung SGH-d807 Cellular Phone
Dell Vostro 1310 Notebook Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
