Question about Mitsubishi WS-55809 55" Rear Projection Television
Manuel for mitsubishi ws-55819 - Mitsubishi WS-55809 55" Rear Projection Television
  • 39 Answers
SOURCE: Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
Posted on Nov 29, 2007
ctf1800
  • 4402 Answers
SOURCE: mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 16, 2008
Slinteriors
  • 8617 Answers
SOURCE: pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Posted on Feb 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
Posted on Jan 22, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-55819 has double vision screen with
Sounds like bad convergence IC's; this set uses two STK-392-570 IC CHIPS; both should be replaced and the blue 3.9 ohm resistors in front of them should be checked. Get someone who has done this repair on this kind of set before--it is usually not something for a do it yourself person; the middle pc board needs to be removed to safely replace the chips; then the set needs to be adjusted in the regular and HD modes. If this is helpful, give me a vote. if you need more direct information email me: etower.766@netzero.net
Posted on Aug 13, 2009
Mitsubishi WS-55819 turns off after about one second upon power up. Help
try the self test: when it goes off press and hold the menu and input buttons at same time for about seven seconds and release both.
power light blinks two digit code like, one blink, two blink, a pause and repeats it several times, this code will indicate area of problem.
sj
May 17, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I need a power supply for a Mitsubishi Medallion WS-55819
did you try contacting the Mitsubishi service center for the part?
Oct 22, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819
you would need the service manual the adjust the vertical size through the service menu
Jun 19, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
May 27, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Nov 22, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws 55819
caps:
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
