Question about Samsung PCL5415R TV
Convergence board Picture is all blue
    Top Expert:
  • Samsung Master
  • 74,634 Answers
A bluish picture is not a result of its bad convergence board. Check its video output card, for any loose solder terminals or damaged component/s. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 04, 2014
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
How can that blue shadow be fixed in the picture.
This tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alingment anywhere in the picture,having colors shadow pictures or 3D pictures look alike?The tv convergence board is dead,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 15, 2010 | Hitachi 50GX30B 50". Rear Projection...
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Toshiba 61H70 61" Rear Projection...
Color is fine but in top right corner have blue and yellow distortion but the rest of the screen picture is ok
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment anywhere in the picture screen.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 09, 2010 | Hitachi 60DX10B 60" Rear Projection...
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Picture has blue at the bottom and yellow at the top. Double images and the station logo is in the wrong place
This tv have convergence problems.Tries website Tvrepairworld.com to buy the whole refurbish convergence board for the replacement.The Samsung/Akai used the same convergence board.
May 15, 2010 | Samsung HCN4226W 42" Rear Projection...
Blue spot on screen
Hi. this is called convergence failure. the convergence board is a circuit board that regulates the RGB(RED BLUE GREEN) streams that make up the color picture. If the convergence board chips are malfunctioning, you will see a distorted view of these RGB streams. This is what you are experiencing at this time.
Simply replacing the convergence board or chips will fix this issue.
Please rate and have a great day:)
May 17, 2009 | Televison & Video
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
611 people viewed this question
Henry  Thomas
Henry Thomas
