Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Touchscreen not working - Universal Remote Control MX-3000 LCD Touchscreen Remote Control
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
Dell laptop touch screen not working
Check all drivers are loaded for the touchscreen interface, if they are remove them and re-install.
If that doesn't solve your issue I would check the cable that connects the touchscreen and that the touchscreen is fitted correctly.
Mar 12, 2014 | Dell Inspiron 7000 series Laptop Universal...
Dell sk2305 @
Sounds like a touchscreen problem, itself.
The touchscreen is NOT part of the LCD screen itself, but when you go to replace, the two units are combined; and sold as one unit.
Examples. NOT advertising. You may find better prices from your search, and reputable dealers also,
http://www.ebay.com/itm/GENUINE-DELL-2305PC-TOUCH-SCREEN-WITH-CABLES-LTM230HT05-/290892243884?pt=US_Laptop_Screens_LCD_Panels&hash=item43ba8763ac
http://www.ebay.com/itm/Samsung-23-Touchscreen-09TW8H-LTM230HT05-Dell-Inspiron-One-2305-/261131794988?pt=LH_DefaultDomain_0&hash=item3cccaafa2c
The different views help me explain the Touchscreen.
The touchscreen uses the Capacitive Sensitive system. Each area on the touchscreen has a separate CS unit for it,
http://en.wikipedia.org/wiki/Touchscreen
Which is what makes me think with two keys not working, the touchscreen is the problem.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 23, 2013 | Dell Computers & Internet
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
My touchscreen is not working after i instal windows 7
Hi.
Based on the information you have provided, it seems that the issue is due to the Driver for the Touchscreen sensors.
As you have changed the Operating System, it is required to install the Touchscreen Device Driver for the Windows 7 Operating System.
Once the Driver is installed, the Touchscreen Device should work normally.
Please let me know the exact Model # of the Computer, so that I can provide you the link to download the Touchscreen Driver.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | Computers & Internet
Installed new touchscreen and the touchscreen does
if the unit is new, kindly contact the vendor for tech-help.
May 11, 2010 | Advantech FPM-3150TVE LCD Monitor with...
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Jun 22, 2009 | Tomtom ONE 3rd Edition GPS
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
140 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
