Question about Pioneer VSX-D409
System turns on but only hear feedback fomr speakser no sound
This reciever i have will turn on and everything works fine except there will be no sound comming from the speakers (which i know speakers r good i tested them) sometimes i will even hear feedback form the speakers and then nothing lol
  • stew2222 May 22, 2009
    hmm, yes there is the click and atm i do have 4 speakers hooked to the a and b (l/f)sides but when playing with the a/b switch nothing comes out (for a minute there was very faint sound till i messed with the a/b switch and no there is not even feedback) and atm i will have to find my headphones plug converter *sigh*
    President:
  • 1,348 Answers
Do the headphones work?that means the pre amp is working.
the speaker protection is maybe activated from shorted wires on the back,there should be a click 5 to 7 seconds after turning it on.
that is the relay that connects the speakers.check the speaker a and b switch. people are not aware of this,but alot of amplifiers ADD the a and b speakers,to prevent too low an impedance from parallel wiring.unless there is 4 speakers,no sound.
Posted on May 22, 2009
ZONE2 RXV673 DOES NOT WORK
Look in the speaker setup menu. The zone 2 speakers usually default to surround back, and you must go into the setup menu and tell it you want to use zone 2.
Dec 22, 2012 | Yamaha Audio Players & Recorders
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
Turns on but no sound
Hi just double check with multimeter for power if thats all good check your rca leads as they send the sound to amp and check that sub out put is on in cd head unit i know these a dumb things but sometimes its these that snag us hope it helps good luck
Oct 17, 2009 | Alpine Car Audio & Video
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
My high definiton is working great and everything is fine except one major thing, which is that there is no sound at all. I would like to know how i might fix this problem.
Good Day, timerwer;
HD is fine but no audio! Not knowing that if you ever had sound, have surround system, hooked to an input or RF, I would suspect that you only have the Green, Blue, and Red cables hooked to your TV and the Audio cables ( red - white ).
If you do; unplug TV (reset, reboot) from A/C outlet for 3 to 5 minutes. If still no work try these suggestions:
1. Make sure the TV's internal speakers are turned 'ON'.
2. Make sure the "BOX" ( cable, sat, u-verse) volume is turned up all the way up.
Good Luck, big IRISH.
Aug 16, 2008 | Televison & Video
No sound from the reciever
Plug in your headphone, if you hear music then it could be the speaker's fuse blown up, or the speaker's circuit breaker shut down. If nothing sound then possibly the strong static has burned down the audio/receiver's circuitry section.
Jun 08, 2007 | Yamaha YHT-440 System
Surround sound problems.
Dolby 5.1 is not supported via either of the Aux inputs. Be sure to check your main menu/audio setup screen to ensure that "stereo" is not selected. If it is, DVD's will not downmix, giving you only 2.1 stereo.
Dec 07, 2006 | GE GTD120 System
Open Questions:
Pioneer VSX-D409 - Remote Control Problem Hello. I'm from Brazil and I have a 12 years old Pioneer VSX-D409 Receiver. My problem is related to the page 16 and 17 of the Owner's Manual. I'm trying to do the steps to Set up the surround mode, changing some settings and the type of connection I use to delivers sound to receiver, using optical cables. Well... I just cannot enter this mode, the surround setting mode. At this moment I'm hearing the sound from a FM station on the speakers. But just this function works. Tuner, wiht FM station. The remote control works only to: - Turn on or off the receiver. - Change the volume level. - Set the loudness function (on or off). - Change the function of the receiver (to select Tuner, DVD, TV or other device in, but I don't gain access to change some specs like distance, speakers volume levels or type of connection of each device). And nothing more. The remote control has seven buttons on the top: DVD/LD, TV/SAT, VCR/DVR, CD, TUNER, CD-R/TAPE/MD and TV CONT. According to the source device you want to use, you just press the button and the receiver selects the IN connection (coaxial or optical or just the Tuner to listen FM stations) and reproduces the audio. Until last week, anytime I press this button, the source device was selected. But, of course, I didn't use all of them. Just two: TV SAT and DVD. Why? This receiver has two optical IN units on its backside. I have two optical cables connected in the receiver. Optical 1 is connected to a PS3 and Optical 2 is connected to a SmarTV. Before my hollyday's trip, all the connections were allright. But not today!! The problem is: I do not have access to the process to change the type of connection that is assigned to the device I've choosen. I want to do this: TV/SAT --> OPT1 (to the audio from PS3); DVD --> OPT2 (to the audio from Smartv); The process is described at the page 16 to 21 of the owner's manual. But, it doesn't starts. Seems my remote control just forgeted how to do this or is blocked in another function. I don't know how to fix it and need some tip or help. Thank You! :)
Jan 07, 2014 | Pioneer VSX-D409
See all Pioneer VSX-D409 Questions
Pioneer VSX-D409 Logo
151 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
