Question about Rexall Temple Touch Thermometer
It is displaying the word "HI". What does that mean?
  • thinksewfast Jan 07, 2014
    Hi susan voda, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What are you taking the temp of when it says "HI".
VinoTemp is displaying "L L"
hi there
what exactly are you seeing now? what exactly is happening?
i have here a pdf of vinotemp and it has some error written.
http://www.vinotemp.com/winmate_instruction.pdf
Jan 24, 2008 | VinoTemp (VINO-24GN)
What does the "prime" mean on the display screen
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 23, 2011 | Keurig Special Edition B60 Coffee Maker
No display on screen but phone works
Hi, you mean work, that after you ON it still can ON but your screen don't display anything( black and no light)
it mean you need to change new screen or ribbon
If it just ribbon problem, it is okay. But if change new screen it need more money to pay.
May 28, 2011 | Panasonic KXTGA560S 58 GHz Phone
When stating the pc the start up tone is working, just it has no diplay.
HI zecjames
connected to an external monitor, if the display out, I mean your display card is still ok.
(mean, lcd or cable connection from the lcd to the motherboard there is a problem)
regards
Jan 13, 2011 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
I cant use my e680i, touch screen not working
hi
if touch screen is not working means kindly restart the phone and try it now.if you still have same problem means then there will be some problem in display panel.kindly change the display panel of your mobile. this will solve your problem..
thank you
Dec 17, 2010 | Motorola Mobility E680i Cellular Phone
No display
Hi,no display is cause by the screen of the phone. You will need to replace the screen of the phone for it to be able to display again.
If the phone doesn't works even when the screen doesn't display,That means it's a software problem.
Sep 23, 2010 | Nokia N70 Cellular Phone
Display only works when it is flipped over
hi, if i understand wath you means that is the pallet
doors display switch /when you flip the panel display
theres a switch in the display doors thats makes the display turn upside down to viewed correctely
i get this problem with different cam i got to fix
that mean :repair is need ,
hope that will help
Mar 09, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
About display
hi.u said u can hear songs.its by default in ur mobile. but if u are unable to view the contents means it might be some display problem and sure u should go for a change
Jan 18, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Rexall Temple Touch Thermometer Logo
90 people viewed this question
Top Rexall Home Experts
john h
Tom Chichester
Are you a Rexall Home Expert? Answer questions, earn points and help others
