How to replace door catch hotpoint ctd80 rumble dryer
Door won't shut
  • 1462 Answers
SOURCE: Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Posted on Sep 07, 2008
  • 99 Answers
SOURCE: Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Posted on Feb 13, 2009
  • 9 Answers
SOURCE: door open light keeps flashing
faulty door lock (part no INT51)
Posted on Jul 30, 2009
barkencoa
  • 3463 Answers
SOURCE: The door catch on my Hotpoint Aquarius WT540
You need to seperate the 2 halves of the door, remove all screws securing the 2 halves together, and prize apart.
You will then see how all the parts are fitted.
Posted on Dec 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
Posted on Mar 19, 2010
Wiring diagram for Hotpoint 31331r door catch
only 3 wires on most dryers one is for light other to shut dryer off when opening if plugged in wrong. dryer will run with door open
light will stay on when door closed reverse them if that happens
some only have 2 wires don't matter on them
need whole model# for more info
Jan 08, 2015 | Hotpoint Dryers
Hotpoint condenser dryer door catch
http://www.repairclinic.com/vwo6/Shop-For-Parts/a8/Dryer-Parts
Oct 20, 2014 | Hotpoint Tumble Dryer Door Latch & Catch...
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
How do i open the door on hotpoint WD440, latch is broken?
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Door won't remain closed so dryer switches off
depends on whether you have a standard catch door or magnets that hold/pull it shut youll be able to tell when you open the door
Aug 07, 2009 | Hotpoint NWXR473EV Dryer
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
Dec 16, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint aquarius ctdoo. the door catch on my dryer is not holding the door shut. do i have to take the outer casing off to get to it to replace it? is it a fairly easy job? thaks for any advice
You should not need to remove tho outer casing, usually the latch is screwed straight to the door, I see if I can find the replacement,
which is your model?
Apr 20, 2008 | Dryers
Dryer won't start up
Does it beep 3 times when you try to switch it on?  If so the door switch is faulty.
Oct 14, 2007 | Dryers
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
