Question about Compaq Presario CQ60-220US PC Laptop
Vertical scrolling not working
The vertical scrolling line on the touch pad has stopped working.
cant find options regarding this in control options as well
hv nt changed any settings afaik
thnx in advance
  • 1 more comment
  • manish_eone May 22, 2009
    hi,
    thnx for the prompt reply
    bt when i double click on mouse properties, i dnt see any option called device settings.
    Also, your point 4 is nt clear to me, i cant see any such option.
    pardon my incompatibility with the device :)
    regards,
    it was installed, bt right now it seems to have stopped working.
    what is the correct hardware, mine shows PS/2 compatible mouse
    n cudnt find any yellow Q marks in device manager :(
  • 108 Answers
You can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
Posted on May 22, 2009
  • 1 more comment
  • Ravi Jain May 22, 2009
    Have you installed the Synaptis touchpad Driver?
    goto mouse properties again.
    Mouse Properties >> Hardware
    See if the correct hardware is selected.
    See in Device Manager for Yellow Question Marks..
    goto www.synaptics.com
    Uninstall existing driver
    Install latest ones
    restart the system
My multi gesture pad scroll stopped working How do I reactivate
Go to Control Panel and check it about the drivers.. if there is change the options.. otherwise install the touch pad drivers...
Mar 31, 2014 | Computers & Internet
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
How do I enable my touchpad scrolling feature?
Right-click on the desktop, then click "Personalize."
Click "Change mouse pointers." This opens the mouse properties window.
Click the "Gestures" tab in the mouse properties window.
Click the "Use Vertical Scroll Function" and "Use Horizontal Scroll Function" check boxes.
Click "OK."
or you might
click "Start" button in the lower left corner of your desktop.
Scroll up and hit "Control Panel."
Choose "Mouse."
Click the "Device Settings" tab.
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll.
hope this helps
Sep 01, 2012 | Dell Inspiron 1520 Motherboard
Touch pad double click is not working. How to cure?
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Jul 09, 2012 | Dell Computers & Internet
Im trying to turn on my touchpad via control panel but when i click the box to turn it on, it wont work
go to acer.com go to support and drivers and download the driver files for the touch pad again that should solve this issue. Follow instructions to the letter and off you should go again unless the touch pad is bad mechanically.
Make sure you input the correct laptop make and model when searching their files. The driver will be there.
John
May 19, 2012 | Computers & Internet
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Feb 21, 2012 | Toshiba Satellite Computers & Internet
I have lost the ability to scroll using the right vertical edge of the touch pad. Otherwise the pad works fine but it is annoying not being able to scroll any more without moving the cursor to the 'scroll...
The option to enable or disable the scrolling option for the notebook touchpad is generally available by going to the Control Panel, then selecting Mouse. Within that area, go to Device Settings, select the touchpad from the list of available devices, then click Settings. There should be an option for "virtual scrolling" - click on it, and you should be given the options to turn on or off both horizontal and vertical scrolling for the touchpad control.
May 06, 2008 | Computers & Internet
Compaq Presario CQ60-220US PC Laptop Logo
1,641 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
