Question about Hitachi 61SDX01B 61" Rear Projection Television
Seeing doubles i have a 61inch hitachi screen tv and the problem with it it that the red lines showing on the side of the pictures its like you are seeing doubles
    President:
  • 1,348 Answers
There is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
Posted on May 22, 2009
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 46F500 46" Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Showing double and red
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 25, 2010 | Panasonic 52LCX1516 52 in. Television
I have double image I am looking at array but not
*Screen Looks 3-D
*Colors wont align
Aug 05, 2009 | Hitachi 50DX20B 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Blue at top of my screen and showing double
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Apr 24, 2009 | Hitachi 51F59 51" HDTV Projection...
I have a Hitachi Projection color TV 57F500. The picture I get on all channels is a double people, double everything. One double is Green and teh other is Red. No other TV's do this and I am using Dish...
*Screen Looks 3-D
*Colors wont align
Dec 05, 2008 | Hitachi 51F500 51" Rear Projection...
Double picture on left side with red projector on Hitachi 55UX58B
*Screen Looks 3-D
*Colors wont align
Oct 20, 2008 | Hitachi 55UX58B 55" Rear Projection...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
173 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
