My alesis Qs 8 won't let me hear out of both sides of my head phones
  • 4 Answers
One probably has a short in it
Posted on Jan 04, 2014
How to hook up the wires of Mackie CR-1604 mixer, to Alesis ADAT xt20 recorder
If memory serves correct you have rca and outs, 8 each. Using rca to 1/4" cords work the best. Connect each of your cords from the "in" on the alesis to the channel access 1 through 8 I believe to the first click. Run the "outs" from your alesis to channels 9 through 16. Use 9 through 16 as playback and 1 through 8 for instruments. This is one good way of doing it with our limited gear. Good luck!
Jun 01, 2014 | Mackie Cr 1604 16 Channel Mixer
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
I AM LOOKING FOR A N ALESIS 8 CHANEL MULTIMIXER THAN CAN BE USED WITH 220V
Since this unit uses so little power, I would recommend a small stepdown transformer. A 20 or more Watt one is sufficient. DO NOT use a convertor that is intended for appliances like hair driers.
Here is a link... the smallest would work and costs $8... I don't know how they can make them for that. You might consider getting a bigger one if you get other equipment to run as well.
Finding the special power adapter that uses 220 and is compatible to the Alesis would cost much more.
Mar 14, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
Has anybody ever replaced an entire crossover assembly (circuit board) in a Alesis Monitor One? Specifically, does the woofer need to come out, and if so, how?
Look here:
http://www.instrumentalparts.com/crossover-pcb-board-for-alesis-monitor-one--mk-1-and-m.html
and here: http://ep.yimg.com/ca/I/yhst-15436568105612_2091_46855693
See that 8.2 mfd bi-polar and one of those white ceramic cased resistors???. Those parts feed your tweeter... One of them is bad. You can buy the board for $30 or spend a couple bucks for those parts.
http://www.mouser.com/ProductDetail/Xicon/140-NPAL100V47-RC/?qs=sGAEpiMZZMtZ1n0r9vR22WuTsnx9Abs03070dCRY8QE%3d
http://www.mouser.com/ProductDetail/Xicon/140-NPAL100V33-RC/?qs=sGAEpiMZZMtZ1n0r9vR22UhSjrTM10DE0iKGiddcDi0%3d
Put one each of the above two capacitors in parallel to make 8 mfd to replace the 8.2 mfd and it will work fine. They only cost 74 cents each. You can find the resistors as well from Mouser.com.
IF YOUR crossover is potted in a hard material, that probablly destroyed the caps. The caps would have to be encased in a foam before hard potting as the shrinkage of the potting material would crush the caps a bit and cause failure.
Feb 02, 2010 | Music
Wont install in my vist computer
I have the same prolem
Can everybody help us please
May 08, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
15 people viewed this question
 Grubhead
Grubhead
