Question about managemylife.com
Dishwasher gdwf16ov40ss dishwasher over flowing with water and not cleaning dishes. turned on disposal cleared but not wont clean. what could be the problem
  • 40 Answers
Might be one problem causing both symptoms. Do your "clean" dishes have a cloudy white film on them? If yes, you probably have hard water. The hard water deposits can clog your machine AND leave your dishes looking dirty. Here's is a link to a map showing the regions of hard water:
http://www.citriclean.net/why-citriclean/
Posted on Jan 31, 2014
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Why doesn't the water draincompletely after the dishwasher cycles?
It drains as part of a cycle as does the wash and rinse cycles.
Most will drain through a hose into a garbage disposal connection. First I would check the grate inside the bottom of the dishwasher for debris them in the disposal. That issue will slow down the water from draining and timing out the cycle leaving water inside. The water when draining from the dishwasher into the disposal should be seen from above flowing out rather fast if correct. If not? The hose from dishwasher to disposal also might be clogged. This is fairly typical issue for dishwashers, when the dishes are not Cleaned beforehand.
Jan 02, 2015 | Dishwashers
DISHWASHER FILLING UP WIYH WATER WHEN NOT IN USE
Check to see if dishwasher drain is attached to garbage disposer. Running the disposer when the dishwasher drains and it will help keep it clean but if the disposer drain line plugs then the water can drain back into the dishwasher. If it does not connect there then you have a slow kitchen drain and this can be fixed by having a plumber snake it. Often it is plugged with grease that can be cleared with boiling hot water poured down the drain. If this is not the problem then check to see if the dishwasher drain is raised as high as it can go under the sink cabinet. Fasten it up with a strap if needed. This will create a trap to keep the water from flowing back into the dishwasher. Do this regardless of your problem. Lastly If the dishwasher does not drain and it is connected to the disposer then the problem is that the knock out plug was not removed when the disposer was installed. Remove the hose at the disposer and knock it out with a screwdriver. This plug is there so you can install disposer without tying a dishwasher in. Otherwise it would leak there. A slow drain may back up and run into the dishwasher before you see any water appear in the sink. If you raise the dishwasher line to the underside of the counter top you should see water in the sink before it begins to drain into the dishwasher. A slow drain may only show up when you are doing a lot of dishes.
Oct 21, 2014 | Dishwashers
Water wont drain
If the water in your dishwasher does not spray or drain properly, there are a number of things you can do. Start by giving your dishwasher a thorough cleaning and see if that helps. See How to clean a dishwasher for step-by-step instructions.
Next, consult the owner's manual for simple instructions on how to access and clean your dishwasher's filter.
Look where the dishwasher drain hose snakes through from one cabinet to the other. Does the hose look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process. You may need an entirely new timer or a new motor for the timer. Repair service is recommended.
If you hear a humming or grinding noise, that's an indication that bits of glass, broken dish pieces, beans or seeds may be caught in the pump impeller.
For more troubleshooting steps and solutions, see Dishwasher not draining. I hope this helps!
Sep 20, 2012 | Kenmore Dishwashers
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Water is not spraying well while dishwasher is running. We had a service call and the technician cleaned a trap clogged with food near the water pump. I think the same thing happened but do not know how to...
You have to remove the sprayer arm, it's cover, and the cover underneath that located on the bottom of the dishwasher, inside the dishwasher. If you find a large amount of grease/food under these covers then you are not rinsing your dishes enough before placing in the washer.
The disposal unit in these units are nothing more than a cheap metal blade spinning over a metal grate. Anything tougher than a piece of cake and it's frosting runs the risk of breaking the gears that drives this.
Clean all the food/grease that you can access. Be careful while removing the gunk, I have found glass shards from broken dishes. Locate the disposal impeller and screen. It can be removed. Inspect it for damage and reinstall after cleaning.
Your water flow can be restricted if this is plugged.
Jul 03, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
My Maytag quiet series 200 is a good dish holder but certainly does not wash dishes - tried different soap all settings only result - dirty dishes - ready to throw it out -
do you have a watersoftner if so may not be working properly if its ok then do you always have water sitting in bottom of tub area. try this fill sink with water on disposal side 1/2 the way open door to dishwasher remove the stopper turn on the disposal do you see water or movement in the tub of the dishwasher if so replumb so the drain does not come into the disposal and plug the disposal opening
Aug 19, 2009 | Dishwashers
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
managemylife.com Logo
46 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
