Question about Coleman Heating & Cooling
How to use a recovery and recyling machine
I dont know how to use the recovery aND RECYCLING machine
  • 52 Answers
What type of recovery machine do you have jhobelamala? do you have a set of guages? what about a recovery cylinder, what type of refrigerant do you wish to recover? do you have a set of scales,and lastly are you a refrigerant handling qualified idividual.
Steve
Posted on May 22, 2009
Robinair Cool-Tech 34700z sending refrigerant to oil recovery container when charging system.
You confirm it by how it functions, if it sticks in a mechanical way there is no electrical testing that would be valid. I would just replace both solenoids.
Oct 13, 2016 | Robinair Cool Tech 34700Z Recovery,...
Scotsman sc275 water pump not recyling water, water pump motor gets hot, machine shuts off.
If the water isn't recycling I would pull the machine out and take the back cover off. Remove the wires that go to the pump, plug the machine in and then with a volt meter measure the voltage and make sure you have 115vac. If so then change the pump. The part that concerns me is that you say the motor gets hot and shuts off. Are you still referring to the pump or do you mean the compressor at the bottom?
Jun 17, 2012 | Scotsman Refrigerators
NEED TO CHANGE FILTER IN COOLTEC 34700Z + NEED FILTER
There is a site www.nytechsupply.com you can down load a pdf manual free of charge. it will have the
instructions and any thing pertaing to your recycling machine. good luck!
Aug 03, 2011 | Robinair Cool Tech 34700Z Recovery,...
The machine will not finish a recovery cylce
Please check you machine compressor suction. It's may need to change
Aug 29, 2010 | Robinair Cool Tech 34700Z Recovery,...
Have the machine in self test mode and dont know what each button
Just read your machine user manual.you will find detail info.about all the button.
NOTE: Do not skip ''self test". because during self test mode machine check it self & make sure that it is working properly.
Jun 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a Robinair 34700, during vacuuming and recycling I lose about 200 g refrigerant gas.
Don't worry this is normal.Because while machine is running for vacuum or recycle mode,automatic air purge device will active for some time & it will purge air from ISV.
May 28, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robin air recovery station for R12, My Question is Can this machine be converted to recyled 134A, By changing the filters? Email to tdrworks@yahoo.com I thank you in advance. Sincerely Santos
Sorry you can not make this only with changing spin-on filter.because have to also change other things such as service coupler,ISV tank,manifold gauge etc.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34700Z Recovery, Recycling, Recharging: when I have the system in a vacuum the liquid freo...
I don't think your machine have any problem! But if you are sure then you can rebuild oil drain solenoid.
May 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
I HAVE A 347007 AC MACHINE, WHEN I DO A LEAK CHECK IT DOES NOT HOLD EVEN IF I DONT HOOK IT TO THE CAR WHAT IS THE PROBLEM WITH THE MACHINE
You need to replace your machine Vacuum check vulve.also check Low/high side inlate solenoid is working properly.
Jun 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
How to clean bar 14
Cleaning the calcium carbonate accumulated inside the boiler.Put only 200 ml of water in the water tank then add a 100 grams of citric acid cristals.Do not use coffee holder and open the machine and wait the heater ready lamp .Start the pump .Collect the pumpes acidic water in a cup.When the cup is filled stop the pump and recyle the water collected in the cup to water tank.Ater repeating this recycling 2 -4 times all crystals will be dissolved and the boiler will be filled with this weak acid solution.Wait the machine closed 2 hours.Then put fresh water and run the pump and remove the solution.Now your machine is free of scales inside the boiler. You will notice less noise during boiling of water inside the boiler(not pump noise).After some usage if you notice again that high noise of water boling it is time for another cleaning.
Oct 22, 2008 | DeLonghi BAR 14 Espresso Machine
Heating & Cooling Logo
60 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
