Question about Toshiba 62HMX84 62" Rear Projection HDTV
Digital greenhouse ballast has blown many times out of warranty need to repair it myself any ovious solutions
Tip
Lamp vs Ballast
This is to help explain the short lives of Lamps.
WARRANTY: If a lamp fails within the first year replace Lamp and Ballast.
If Lamp explodes do not replace Ballast only lamp, but if lamp didn’t explode replace both.
If you experience more than one Lamp failure within one year of use replace the Ballast.
The Panasonic Brand offers a Ballast repair kit (LSUC0022), it only works about 20% of the time.
I would not recommend this replacement kit. It will get you past the 30-45 day warranty period in most cases but it will not be the proper FIX to the customer’s unit and they will only call you back or (most important) call another Service Center.
I have experienced maybe 100 customers that had other Service Companies come out and only replace the Lamp. When the Lamp and Ballast should have been replaced.
I hope this helps the Customers and the Technicians in their judgment.
If I was redundant I apologize, just trying to help.
Good Day, big IRISH
on Dec 09, 2009 | Televison & Video
My son turned on my 1080pi tv last night and heard a loud pop and then smelt a burning smell. Do I need to take this to a repair shop or can I fix it myself? What would the cost be?
Hello
Something bursted out inside your tV. Probably it will be a mains filter capacitor. If this type of capacitor bursts out, it will spill the electrolyte liquid all over the surroundings, which is an electrically conductive material. So never turn ON this TV until it has been throughly cleaned and repaired. Power supply board inside your Tv is faulty. OK.
May 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Powers off and power lamp flashes five times... pauses and flashes again...
A "5" blink error on your set refers to one of two problems:
1. The ballast circuit board
2. The lamp.
If it were under warranty, I would replace both, and guarantee myself that the set would be fixed.
Sometimes, when the lamp fails, the ballast throws a "5" error. However, it is possible that is both parts are in need of replacement.
Pull your lamp and take a look at it. Is the surface cloudy? Is the lamp imploded? Is the filament broken?
If so, replace the lamp first. See how it holds up.
Jan 24, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red light blinks5 times stops & does it repeatly sony KDF-60WF655
5 times red light blinks in Sony KDF-60WF655 shows problem with ballast supply that needs to be replaced.
If you are handy with electronics stuff repair and have service manual copy then can replace it.
Be Aware: electric shock risk is involve in TV repair.
Or contact local TV tech to fix it.
Need further help, let me know please.
Thanks.
Sep 22, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Trying to find a ballister circut for a toshiba 62hm95 and is it something that i can replace myself
The Ballast is the correct wording.IT has four
screws and plugs into the lamp.very easy to change.
Sep 04, 2009 | Toshiba 62HM95 62" DLP HDTV
Samsung hln4365w no powerup flashing lamp & temp. can i repair myself & where do i get parts?????
There should be a lamp code sticker on the left side of the tv.bp96-00224c or bp96-oo224a are the part #'s for the 2 lamps used on this set,but you need the right one or it will blow prematurely because of 2 different ballasts used.
Aug 22, 2009 | Televison & Video
STANDBY LIGHT BLINKS 6 TIMES
Just because you have replaced lamp does not mean that this one is not Bad,Did your order orignal Sony Lamp? Also have you CK Ballast board it is what fires lamp? You could have Bad Ballast Go to E-Bay thats were i have found Good Deals on Lamps and Ballast Boards Find them on Auction ,Also your lamp should still be under warranty find out if so get another one CK power supply board look for any capacitors to be bugled/Puffed up on Top if they are they are Bad this can cause lost of start,and if you have a bad fan can cause startup failure.Fan that keeps Lamp cool.most have at least 3 Fans.Let me know if you need any more help Heres you another tipp fined out about warrant on your Light Engine Sony Had Alot of Bad Light Engines and has up warranty on Sets for this Part IT IS VERY Costly they start at $2,500.00
Aug 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
No summary necessary...nailed my problem to the letter.
The ballast board is stand alone. There is a bad capacitor in the power supply. It may be 820uf, but look for any that have the tops bulged or leaking juice.
Aug 07, 2009 | Mitsubishi WD-73733 73" HDTV
X2 board
ebay has several that need bulbs... just a thought here is one of the item numbers Item number: 270207032811
Jan 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
