Question about Char-Broil CharBroil 4637318 Grill
Char-Broil 463722313 chain
There is a chain with a loop-hook pre-attached to the leg underneath the side burner. What is it for?
    Problem Solver:
  • 8 Answers
Think its a match holder, if the spark doesnt work, you can place a match on it, light it and lower it down to ignite the gas...
hope this helps
Posted on Jan 11, 2014
4 Suggested Answers
SOURCE: Need instructions for assembly of char-broil gas grill
mine wont line up i need help
Posted on Oct 10, 2008
  • 8 Answers
SOURCE: Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Posted on Aug 05, 2009
  • 221 Answers
SOURCE: I need a manual for a Char-Broil H20 Smoker. Is
Go to this link and you should see a download for your smoker on the right hand side of the screen.
http://www.charbroil.com/ProductSupport/06701311/Electric-H2O-Smoker.aspx
Hope this helps.
Posted on Jun 21, 2010
Pre-attached chain with loop-hook
Most BBQ makers know that their ignition system will be the first thing to break so they give your a small match holder. The loop holds a short match so you can lower it down to light the burners manually, the chain just connects it to the grill so you don't lose it.
Jan 04, 2014 | Char-Broil Grilling
Chain with clip attached to leg side underneath side burner. What is it for?
hope this helps
Jan 04, 2014 | Char-Broil CharBroil 4637318 Grill
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
Which way do the burners attach on a King Griller Stealth Model#3008
I mounted them ignite side down and used channel locks to flatten the metal ears and attach the coterpin simultaneously ... worked first try
May 08, 2011 | Char-Broil CharBroil 4637318 Grill
Need to know where to connect igniter button to where side burner is still connected not main burners
According to your Owners Manual, the side burner uses the same electronic ignitor as the main burners. I know that sounds odd, but that's what Charbroil often does with their igrills.
To help you with further insight and in case you've misplaced your Owners/Assembly Manual, I have included a link to it that you can download and print for future reference, if you like.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 23, 2011 | Char-Broil Advantage 463453306
I am trying to remove burners to clean. I have removed carry-over tube but can't get burners out. They seem to be in a bind. Are they attached anywhere or do I just pull out?
Look closely, where the spark ignitor touches the burner. You will see 2-sheet metal screws that attach the burner to the floor of the grill's casting. If you can remove those, the burner can be removed and slid of the venturi valves. These sheet metal screws will probably be covered with grease and a bit rusty. So, use caution when trying to remove them.
If it will be of any help and for future reference, I have included a link to your Owners Manual, that you can download and print.
Hope this helps and Happy Grilling!!
Apr 12, 2011 | Char-Broil Advantage 463453306
Have model 463728504 char-broil withno manual and I do not knowhow toturn side burner on
Here's a link to your Owners Manual, that you can download and print for future reference. Pay particular attention to Page # 8 (lighting the burners).
Happy Grilling!!
Apr 10, 2011 | Char-Broil Advantage 463453306
Where do you hook the sideburner ingintor wire to?
You connect the wire to the pin on the bottom of the peizo ingnitor (it looks like a 3/4"' needle) . The sleeve on the end of the wire should just slide onto the pin. Make sure you push it on snugly. You'll find it underneath the side burner.
Hope this helps to get you up and grilling. Please let me know. Thanks.
Mar 13, 2011 | Char-Broil CharBroil 4637318 Grill
Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Jul 02, 2010 | Char-Broil CharBroil 4637318 Grill
Char-Broil CharBroil 4637318 Grill Logo
66 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
