Question about Whirlpool Refrigerators
I have a whirlpool ed26qf that stopped cooling. the compressor is very hot and is clicking off and on. is there an easy fix or easy way to find the problem
I bought the fridge used. the fan in back is working. there is no air flow problems for the compressor cooling.
  • robert canary
    robert canary Jan 04, 2014
    i took out the relay,no burnt smell but it rattles loudly.i cant find anything to say how old it is but i was told 5 yrs old. the compressor is a embraco EGS 90
    Problem Solver:
  • 5 Answers
The compressor is overheating and tripping on thermal overload. Check the condenser and find out if it's dirty. Most of the time, people don't realize the condenser, is usually located under the unit. They get filthy and can't reject the heat the refrigerant picks up in the box. If that's not it, you're probably either low on gas or your compressor is going bad.
Posted on Jan 04, 2014
esanto2
  • 3 Answers
SOURCE: Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Posted on Dec 07, 2008
SOURCE: relay clicking, not cooling either side
asdsad asd
Posted on Mar 22, 2008
  • 306 Answers
SOURCE: Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 18, 2009
  • 770 Answers
SOURCE: Kenmore coldspot 106.54563300 is not cooling.
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Posted on Jun 21, 2009
woodchuck789
  • 4059 Answers
SOURCE: side by side not cooling
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Posted on Jul 05, 2009
Whirlpool Refrigerator neither cools nor freese
Have the model number? Can you feel the top of compressor to see if clicking or getting hot trying to start? 3_5_2013_2_17_27_pm.jpg
Sea Breeze
Nocking on refrigerator anywhere and starting is a loose or defective connection like a defective thermostat will cause these symptoms.
Mar 05, 2013 | Whirlpool Refrigerators
Whirlpool ed5gvexvd00 stopped cooling. Compressor felt hot. Compressor come on for a few seconds and then shut off.
Hello, Thank You for using FixYa. I will be helping you today.If the compressor is hot and shutting off and fan in back bottom is working the relay on the compressor is bad or the compressor is bad. If your trying to fix yourself start with the relay on the compressor if that dont work its the compressor and if its out of warranty it will cost about $500 to change. Pull the relay off the compressor and shake it sometimes you can hear it burnt out sounds like sand in there.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Whirlpool Refrigerators
The gasket around my refrigerator is too hot to touch, what is wrong?
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Jun 07, 2010 | Whirlpool Refrigerators
Heated panel
May 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Very hot frame
May 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Nov 12, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool side by side does not cool at all
Simple Fix. That's cost around $40. You need to replace your relay/overload. Its mounted on the compressor. It should have a black box over it. Take it off then pull the part off the compressor and replace it with a new one.
Jul 30, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
