Question about Char-Broil CharBroil 4637318 Grill
Chain with clip attached to leg side underneath side burner. What is it for?
    Problem Solver:
  • 8 Answers
Think its a match holder, if the spark doesnt work, you can place a match on it, light it and lower it down to ignite the gas...
hope this helps
Posted on Jan 11, 2014
Flapper chain suddenly started disconnecting after every flush. Length is adjusted correctly. There is play between the flush lever and arm that pulls up the chain. Could that be the culprit?
If the chain disconnects then obviously the clip that is meant to keep it attached is not functioning properly. Just look closely at whether the clip is bent open, twisted, etc. Should not be hard to fashion something to keep the chain attached. Length has nothing to do with the problem.
Jun 05, 2016 | Home
Tip
All purpose presentation easel a DIY project
You never know when you are going to need or want an easel to show off your art work, maybe your kids want to finger paint who knows they could be the next Van Gogh. Building a display easel is very simple and can be done in just a few hours.
You want to start with two pieces of wood cut to 2x82" these pieces will form the front legs of the easel. Using a table saw cut the tops of the wood to a 15* angle. Take a measuring tape and measure 78" from the bottom of the wood (up to the angle cut) mark this spot on both pieces.
Using a drill, drill a 3/8" hole through the widest side of the angle as a right angle to the cut. Repeat for the second front leg.
To make the back leg cut a piece of wood down to 2x81" long, using your drill, drill two 3/8" holes in the widest side of the wood. One hole should be 39" from the bottom of the wood and the second at 74" from the bottom.
Your art work needs something to sit on so to make the cross bar cut a piece of wood down to 2x47".
Now you are ready to assemble your easel. Take the front and back legs and lay them on the floor next to each other with the back leg in the middle. Rotate the front legs to the angle is facing the back leg and line up the holes. Slide a bolt into the hole and place a washer and a nut on the end, keeping it loose enough to adjust the angle. Stand up the easel and spread the from legs so that they are 45" away from the back leg. Tighten the bolt and you have the angle right and lay it back down.
To attach the cross bar, measure 38" up from the bottoms of the front legs find the center and drill a 3/8" hole in each and bolt the cross bar to the legs. To keep the legs from spreading too far you can attach a chain between the cross bar and the back leg. To do this you thread the chain through the hole in the back leg and tie it off. Attach an eye screw to the cross bar and loop the chain through it to keep limit how far the legs can spread to the angle that you want to work or display at.
on Jan 29, 2014 | Office Equipment & Supplies
Tip
Gaining a few extra inches of leg room, driver seat.
1. move the drivers seat all the way forward 2. from the back seat, locate the clip attached to the right side drivers seat rail. 3. lift the clip up using a screw driver or pliers. The clip is flexible metal and can be removed and replaced without harm.
on May 19, 2008 | 2007 BMW 750Li Sedan
Can not get spring in the kickback lever assembly
The return spring is not supposed to come out, however, remove the e clip and pull out the pin, the spring has a loop at the an arched leg and a leg with a pig tail. Press the arch leg and the pig tail leg together and push the loop up into the hand guard with the pig tail facing toward what would be the rear of the saw, push it up as far as it will go, push the pin back in and re fit the e clip, the arch leg of the spring should now be resting on the top of the pin if you have done ir correctly, and the tail of the pig tail should be protruding.
Mar 27, 2014 | Husqvarna Chain Saw 20" Bar
Pre-attached chain with loop-hook
Most BBQ makers know that their ignition system will be the first thing to break so they give your a small match holder. The loop holds a short match so you can lower it down to light the burners manually, the chain just connects it to the grill so you don't lose it.
Jan 04, 2014 | Char-Broil Grilling
Char-Broil 463722313 chain
think its a match holder, if the spark doesnt work, you can place a match on it, light it and lower it down to ignite the gas...
hope this helps
Jan 04, 2014 | Char-Broil CharBroil 4637318 Grill
Overhead door opener 555 with manual release won't lockup chain
Sometimes if the clip is not reset then it wont catch the chain mechanism again to open or close the door. If you havent already reset the pull cord clip then that would be my guess. Try closing the garage door reset the clip with the rope attached, push it up til it clicks. and hit the garage door opener button. the rope and clip should move along the track until it hits the arm bracket where the garage door attaches to the chain mechanism.
If that does not do the trick then the clip has some screws on either side of the plastic casing and may need to be loosened and readjusted to match up with the garage door arm bracket and then locked back into place. That should do the trick if all esle fails, you may have to call the door company to come and correct the problem. Hope it works out!
May 28, 2012 | Home Security
Can you please let me know how to wire in a GSW-31 pull chain switch interupter. Thankyou
Hi and welcome to FixYa, I am Kelly.
You wire it up in series... Usually you cut the black wire and install the switch wires between the cut wires. All the switch does is open 1/2 of the circuit. (one leg) If your power wire is not black then find the power wire attach one side of the wire to incoming power and attach the other side of the switch to the load / light / fan / what ever.
Thanks for choosing FixYa,
Kelly
(Electrician since 1960's)
Mar 26, 2011 | Gardner Bender Gsw-31 Pull Chain Switch...
What tools do i need to change the headlight in a 2005 kia optima
No tools on the left side but on the other side with the battery.
You will need to take out the battery.
Just screw the cap off inside which is behind the headlight.
There is a clip in there.
Just un-clip it . It is a clip that attached underneath after when you take the clip off.
Remember how you un-clip it !!!
That way when you clip it back in , it will be alot EASIER !!!
Don't touch the tip of the headlight BULB.
Jan 29, 2010 | 2005 Kia Optima
Kenmore 90 series agitator problem.
usually it is a gearbox drive coupling, designed to break on exceptional loads
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models
  • remove trims from ends of control panel
  • remove scres under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Jul 13, 2008 | Roper RAS8445KQ Top Load Washer
Char-Broil CharBroil 4637318 Grill Logo
59 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
