Question about General Electric Profile DPSE810EGWT 7.0 Cu. Ft. Electric Dryer - White
GE Profile DPSE810EG0WT electric dryer display cycling after the control board was changed. Dryer starts, but when button pressed to stop the dryer, the display starts cycling through these letters: P, Pa, AU, US, SE, E. These look like country codes to me but I have no idea how to reset? Other than this, the dryer displays the selected cycle time and runs OK. Issue occurs when cycle is stopped by pressing the button
  • 51 Answers
PAUSE? If you stop the dryer before it is done completing the dryer cycle you have paused it.
Posted on Jan 06, 2014
  • 3422 Answers
SOURCE: GE Harmony Profile Dryer DPGT750EC1PL not heating & blower not working
HI,
If your blower stops working, the element will overheat and trip the high limit, thats is why you have no heat.
The trick is to find out why the blower isnt working. It should be found under the dryer. Its possible that there may be a loose wire. It could be getting ready to go out. I would run the blower motor, observe it when it stops, then take a voltage reading. If voltage is presnet at the blower motor, and the motor isnt working, then the motor needs to be replaced. If voltage is not present, then we must determine why.
If your dryer is not getting any heat, you need to make sure there is nothing blocking the front of the dryer. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome. Check the coil for continuity with a Volt Ohm Meter. If there's no continuity, it means that the element is bad and you need to replace it. An electric dryer should have it's own separate power line.
When the burner is operating properly, the flame should be clean and blue.
If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
If the ignitor doesn't glow, look for a white or yellowish discoloration, or for a break in the ignitor. If this is something visible, just replace the ignitor. If there are no obvious signs of a break or burnt area, test it for continuity. If the ignitor doesn't have this type of problem, you'll need to determine if the problem is in the control area, or somewhere else within the burner system. Test for 110v getting to your burner assembly.
Here's a test you can perform: Unplug your dryer and then open up the burner inspection panel. Unplugging your burner assembly unit, you want to connect your jumpers for the Volt Ohm Meter to the dryer side of the assembly, not the burner side. Keeping your Ohm meter wires away from the drum area, set the timer to on, set the controls to high heat, and then plug the dryer back in. If there is 110v in this area, you can assume the thermostats in this area are good. If not, a timer, motor centrifugal switch, or other thermostat may be your culprit.
To protect from over-heating, many dryers use what's commonly called a thermal fuse. If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It's about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
You should visually inspect the wiring connections to the dryer from the house regularly. If you're opening the dryer case, give the wiring inside a good visual check as well.
Lastly, never use an extension cord to operate this appliance. An electric dryer draws a lot of power, and the shorter the wiring to it, the better. The power cord connects to a terminal block in the back of an electric dryer. Sometimes this terminal can get burned out or ground to the dryer. Make sure the power is turned off, and look for scorching, burned, or broken connections. For electric dryers, one broken connection might allow the dryer drum and timer to operate, but there would be no heat.
If your clothes are wet then:
This is usually caused by poor airflow. Turn your dryer on and go outside to the vent. If there is not a strong airflow, check your dryer duct vent, lint trap, blower, and also look for clogs and kinks in the vent hose or ducting. Ductwork inside the dryer may become clogged. Use a long flexible lint brush or vacuum attachment to clean these ducts. Make sure the air path is clear from the burner assembly or heating element all the way to the exhaust vent.
Some electric dryer heating elements have two circuits in them. Sometimes one can burn out. If one part is not working properly, this can lead to a dramatically longer drying time. If this happens, you'll want to just replace the whole heating element since the individual circuits are not available separately.
Another reason for damp clothes would be one of the cycling thermostats. These control the temperature in your dryer and when they fail, they prevent the dryer from heating well or stop it from operating altogether. To locate and replace a thermostat, follow the duct work that moves the air through the dryer. A thermostat has 2 to 5 wires attached to it, and the body is black or brown. On the end opposite the wires is a metal plate that is used to attach the thermostat to the duct work.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 07, 2008
revamos
  • 16 Answers
SOURCE: GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Posted on Apr 20, 2008
SOURCE: error code e 61
same description , the same problem:I
had a power surge and now my G.E. dryer is showing Error Code 61. How do I reset it? I have turned the breaker off and on but this doesn't fix it.
I am JD and my e-mail is : averescribe@hotmail.com
Thank you all¡
Posted on Sep 08, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Posted on Jan 24, 2009
  • 864 Answers
SOURCE: Reset GE Profile Harmony Dryer
Try here: http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Posted on Sep 15, 2009
How to get error codes
With the dryer OFF Press the following sequence of buttons My Cycle - Delay Start-My Cycle - Delay Start . Menu will come up. Scroll down to Error codes and select. Scroll using arrows through error codes
Mar 26, 2014 | General Electric Profile DPVH890EJWW 7.5...
Tip
GE Profile Harmony DPGT750EC (Electric)
Are you having problems with your GE Profile Harmony but don't know where to start to troubleshoot? Let the dryer do it for you, here's how:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
The system will give you a description of possible hardware failure and troublecode.
Replace the failed piece of hardware and plug your system back in. It will go through a boot-up sequence and verify that your machine is working once again.
on Apr 30, 2009 | GE Profile Harmony DPGT750EC Electric...
My bravo steam dryer is showing an F1 code, and I can't get it to start
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
Mar 05, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony gas dryer heats up but blower work 2 min. then stops
Have you access the dryers service mode? If not, access it and see what error code you get. Follow this:
Once you know the error code, post it or email me and I can help you from there. jeryflores@hotmail.com
Apr 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Electric Dryer - Starts out heating but then screen says SENSING
nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
Dec 03, 2007 | GE Profile Harmony DPGT750EC Electric...
General Electric Profile DPSE810EGWT 7.0 Cu. Ft. Electric Dryer - White Logo
174 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
