Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Chair turning left only - Pride Jazzy Select 6 Indoor Power Wheelchair
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Check the lever to the right motor make sure it is engaged if it is then u may need a right motor
Posted on Jan 19, 2014
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I have a htt 9c chair. it was working yesterday. I went to use it today and it would not turn on. it has no power and circuit is fine. please help
First, check the power with a volt meter on the receptacle you are plugged into. (or plug a lamp into the receptacle and make sure it turns on. believe it or notI have seen this many times) If power is fine, then remove the back of the chair (with the cord unplugged) and stabilize the back of the chair as the wires hang from the back of the chair to the chair itself. Plug back in your chair and check power to the on/off switch on the back of the chair, if you have power there then it gets a little more complicated. Again, unplug the chair, remove the black plastic cover on the lower left of the chair that covers the main circuit board. You should see a soldered in fuse, use an ohm meter and check the fuse for continuity. If it reads good or "shorted" then you are past my knowledge in this matter. Hope I could be of some assistance.
Jun 28, 2011 | Interactive Health New Htt 9c Curve Track...
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
The right wheel seems not to be working smoothly. When I try to drive straight it veers to the right slightly, like the left wheel has more more. It is also hard for the chair to turn left because the...
Hi Jack
Sounds Like all you need is for a technition to program you chair. They can do an adjustment to compensate the different strengths of each motor and make the chair run straight Also to improve the turning speed adjustments. Programer is a P&G PP1
Good Luck
mimobility
Apr 26, 2011 | Pride Jazzy 1103 Ultra Standard Power...
When i turn the on switch three red lights flash on the left side
glenn You have a left motor fault and the motor will have to be replaced. If Medicare paid for your chair they will pay for 80% of the repair costs. Contact Repair Express @ 877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both great service companies that will send a tech out to pick up your chair and leave you a loaner to use. They will bill Medicare for all repairs and get your chair back to you all ready to go You can also check with your provider to see if they will repair it for you Hope this helps
Mar 01, 2011 | Jet 3 Ultra Power Chair
When I turn my chair on it shows me the level of charge by turning the little ligths all on, but as soon as I move the joystick at any direction it does a little sound like a breaker popping and the little...
The code indicates bad left motor wiring or connection. Check the left motor wiring connector and if it looks ok then you will need to replace the left motor. If medicare paid for your chair they will pay for most of the repair cost. you can contact repair xpress @ 1-877-581-3733 or roadrunner mobilty @ 1-800-467-2668 these are two great repair companies that will bill Medicare for the repair cost. Hope this helps
Oct 10, 2010 | Jet 3 Ultra Power Chair
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
78 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
