Question about ViewSonic VA1703wb Monitor
No Display on Screen
Hi guys of Fixya, I have this Viewsonic VA1703wb 17" monitor. My problem is that there is no display but the power led in on - "green". I have tried to open and found 3 bulge caps. After replacing, the same problem exist. What are my other options except replacing the whole LCD?
SOURCE: vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
Posted on Jul 13, 2007
SOURCE: Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
Posted on Dec 08, 2007
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
SOURCE: No display, green light on ViewSonic VP201b 20.1 LCD
I have two broken VP201 monitors with different symptoms. One was black screen green light - like yours. The other was purple speks flying all over the screen., purple tint.
I swapped the power supplies and display boards, both monitors had original problems. I swap the inverters and the monitor which was black screen now appeared to work okay - but slightly pink and the monitor which was purple speks is now black screen.
I would therefore assume that both my inverters gone, one being on it's way out. You probably have the black-screen case.
Posted on Aug 27, 2008
SOURCE: viewsonic vp930b-3
Same symptoms with no display and blinking green light. My monitor had been having a distorted image occasionally and a subtle whack on the side would clear it up for a week or so. I replaced both of the 1000uF 16v caps and both 250uF 25v caps on the power supply. All 4 were bulging before. Powered up and all looks good. Thanks!!
Posted on Oct 06, 2008
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 19, 2010 | ViewSonic VA1703wb Monitor
Just bought a new viewsonic vga1703wb monitor. Plugged it in and turned computer on. Microsoft display comes up and then screen goes black and says 'no signal'. Can you help?
shut down the computer start it again press F8 immediatly and keep pressing untill menu appears highlight on "enable VGA mode" and press enter, your problem will be solved
Apr 11, 2010 | ViewSonic VA1703wb Monitor
View sonic va1703wb model no: vsa11534 serial no: qfcko70600651 is it warranty please tell me because my mointor was no display
Follow the following steps:
To obtain warranty service, email service.us@viewsonic.com.
To obtain warranty service, the following will be required :
The original dated sales receipt (include reseller name, address, phone #, product model, product serial number, and your name if applicable)
Your name
Your company name
Your shipping address (no P.O. Boxes accepted)
The serial number of the product
A description of the problem
Regards
Ashly
Feb 03, 2010 | ViewSonic VA1703wb Monitor
VA1703wb Viewsonic Monitor backlight
The problem can be bad power supply feeding the backlight inverter circuits due to bad caps, or in the inverter circuits, or worst case will be bad lamps, you need to open it up and tell us what you see inside first, good pictures will help, see example of failed VIEWSONIC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | ViewSonic VA1703wb Monitor
Hi i am using viewsonic lcd VA1703WB monitor.i am getting a horizantal line in the middle of the montor.i bought the system in jan07.please give a proper advice to rectify the problem.
The most likely cause is blown diodes in the screen.
You will have to take it to your local Viewsonic agent to check it out.
Best wishes,
Graemevm
Nov 13, 2009 | ViewSonic VA1703wb Monitor
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
The screen resolution
Your going to love this. Open control panel, open display. Click the settings tab. Click Advanced. Click the Monitor tab. Remove the check mark from "hide modes". Click the drop down menu & set it to 75 hertz. Click Apply & than ok. You are now back to the Settings window. At Screen resolution move the slide bar to more. Pick what you want. Again click Apply & than ok. Bingo there you are! Have a nice day.
please vote...
Nov 18, 2007 | ViewSonic VA1703wb Monitor
Screen display
You should be able to adjust these settings in the display settings which should be in the controll panal some where depending on which operating system you are using and what graphix card.
Sep 08, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VA1703wb Monitor Logo
244 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
