Question about John Ertl 132 John Deere 648g Log Skidder
Put transmission in gear and won't go, code comes up
Code 330
06 polaris 330 magnum wont move in any gear , whats the problem? where do I start troubleshooting?
Make sure the spring on the brake pedal that operated the park interlock hasn't stretched or come off the interlock, If the interlock and spring are ok,the problem most likely is behind the gear selector cover on the transmission. Water,moisture can get into this area and corrode the shift gears up or possible you could have broken tooth on one of the small gears
Oct 25, 2016 | ATVs
Polaris 330 magnum won't come out of gear.
Was it cold out side when this happened . Mine did the same thing and water got in to the box then it would freeze it .
Apr 20, 2013 | Polaris ATV
2003 ford explorer transmission won,t pull in any gear.
check make sure transmission fluid not too low or could have plugged transmission filter.or code scan for faulty transmission fluid pressure sensor or transmission range sensor bad or out of adjustment.transmission could have failed.garage has to run fluid pressure test see if transmission failed or you could have faulty shift solenoid..
Feb 26, 2013 | 2003 Ford Explorer Sport
Transmission won't go into gear makes a chime when
Check the transmission fluid, run the vehicle at operating temperature,vehicle in park check the transmission fluid level if the fluid has the correct level you are dealing with a failed transmission,and a replacement or a rebuild is the solution
Mar 28, 2012 | 1994 Dodge Caravan
The speedometer is not reading at al and at the same time it won't upshift out of low gear
two problems you may have.one is the speedometer sensor may not be working thus the transmission won`t know what gear its suppose to be in.the other is the transmission may have gone into back up mode as the tcm may have detected a transmission problem.have the tcm and the pcm checked for codes to help find the problem.
Oct 26, 2011 | 2002 Dodge Grand Caravan
My estima has gear shifting problem.
Hello Riaz, did your check engine light come on? If so it would be very helpful to know what the codes are for my diagnosis.
Your cars problem could be one of two things at this time, codes will tell more. Your car is having a problem with a shift soleniod, or a problem with a stuck valve body.
Try this first, it won't hurt anything, go to your local auto parts store and buy a quart of LUCAS transmission treatment. Put about 1 pint into your transmission, this stuff will dissolve and lubricate the inside workings, and as I mentioned will not hurt anything and at this time will be the least expensive route.
If you get back to me with codes I may be able to help you further.
GOOD LUCK.
Oct 21, 2011 | 2007 Toyota Yaris
Transmission distance sensor (code P0707) where is this located? My problem is the RMP goes in high, the check transmission comes on, if you put it in park and the light or stop, you can't give it any...
Transmission distance sensor ?????? P0707 Transmission Range Sensor A Circuit Low Input Transmission Control Module - AISIN Transmission REFER to Section 307-01B .
My problem is the RMP goes in high,???? RPM P0707 TR sensor TR sensor circuit low input TR sensor signal is below threshold of 0.127 volts, sensor/circuit electrical malfunction TR sensor indicates a stuck position (D-3rd gear), no adaptive or self learning strategy. Install a new TCM.
Your best bet ,take your vehicle to a ford dealer .
Oct 01, 2017 | 2005 Ford Five Hundred
Forward gears working fine but reverse is week
the reverse band needs to be adjusted.
Jun 28, 2009 | 2001 BMW 330
John Ertl 132 John Deere 648g Log Skidder Logo
65 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
