Samsung closed caption
How do I get closed caption off my tv screen?
5 Suggested Answers
crlee3
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
Posted on Sep 08, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
  • 304 Answers
SOURCE: Samsung LCD tv no sound from one channel only, no
First try viewing regular programming and see if you have audio on both channels. If you do not then go to the user menu and make sure that the chim function is turned "on". Then turn off the tv and listen for the down chime coming from both speakers. If you only hear the chime from one speaker then the Aidio circuits are bad on the Main bd and needs to be replaced.
Posted on Jul 16, 2009
bshldn
  • 736 Answers
SOURCE: 2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Posted on Nov 09, 2010
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
One caption frozen on screen
I believe this is associated with closed caption settings. This can be found in your setting menu, most likely under video. In there turn off CC.
Apr 02, 2014 | Samsung Televison & Video
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Logos on the bottom of the screen won't disappear
that logo is CC close caption..to remove it go to the menu and find close caption option then select off then press enter..
Jan 02, 2012 | Samsung LN32A330 32 in. LCD TV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
