Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Changing code on keypad - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Posted on Feb 01, 2014
Kyocera service codes
It's a firmware mismatch error did you just replace the touch screen or the whole control panel
Aug 25, 2014 | Kyocera Km-4050 With Feed, Finisher, Bank,...
How do I reset the code after changing the battery?
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker (more about that below).
"How can I program my electronic keypad lock when the instructions with the programming code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Sep 17, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Changing the code for craftsman garage door opener
These are the instructions for changing the code for the keypad. If you are looking for something different post back.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hello I have an Access Master Chamberlain garage door opener and i never had to change the garage code. Can u assist me in changing the code?
Well I have to assume you want to change the code for the keypad because that is the only code you can actually change. Locate the smart/learn button on the rear of the motor unit near where all the white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jun 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Changing code to garage
If you are talking about a wireless keypad do this: On the rear of your motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your new code and press enter.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
THE KEYPAD NO LONGER ACCEPTS MY 4-DIGIT CODE. MUST HAVE HIT THE STAR KEY OR SOMETHING & ERASED IT. HOW CAN I RESET IT? THE INSTRUCTION ON THE PAD LET YOU CHANGE IT, BUT SAYS NOTHING ABOUT RESETTING...
If your battery is good and you have followed the instructions for changing it then your keypad is bad. The instructions for changing the code is the same as resetting it.
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad will close door, but not open it!
Try changing the battery and reprogam the keypad. The code remains active for about 30 sec. after it is entered into the keypad which allows you to press enter to change direction of the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
372 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
