Question about LG Washing Machines
Flashing prewash and crease care lights - LG Washing Machines
  • 66 Answers
Problem with the water pressor,,its not maximum pressor 5 bar,,
Posted on Jan 21, 2014
4 Suggested Answers
  • 1314 Answers
SOURCE: Wont start... all temperature lights flash and the Prewash,rise,time save, crease care lights flash too
try unpluggit then plug it back in is it giving any trouble codes
Posted on Dec 30, 2007
SOURCE: prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Posted on Jan 25, 2008
barkencoa
  • 3463 Answers
SOURCE: why Prewash light is flashing?
I think you need to clean pump filter, if not at front, then remove lower rear panel of washer, locate and remove large black hose on drum ,remove and clean filter inside, remove hose onto pump and check for obstruction there as well.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
During the first cycle of quick 30 i.e.in wash cycle water flow is very slow & no sufficient water flows through the detergent drawer.After some time it throws out water & both prewash n crease...
Remove the inlet water hoses to the washer and check the screens going in the ports for buildup and verify good flow coming out of hoses into a pail
Jan 28, 2011 | Washing Machines
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
May 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
386 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
