Question about LG Washing Machines
Flashing prewash wash and crease care lights - LG Washing Machines
  • 1314 Answers
SOURCE: Wont start... all temperature lights flash and the Prewash,rise,time save, crease care lights flash too
try unpluggit then plug it back in is it giving any trouble codes
Posted on Dec 30, 2007
SOURCE: prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Posted on Jan 25, 2008
hards327
  • 30 Answers
SOURCE: Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
Posted on May 15, 2008
barkencoa
  • 3463 Answers
SOURCE: prewash light on machine will not go into next mode wash ?
Check pump and filter for blockage.
Posted on Dec 14, 2008
localwonder
  • 6784 Answers
SOURCE: NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
Posted on May 11, 2009
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
Flashing prewash and crease care lights
problem with the water pressor,,its not maximum pressor 5 bar,,
Jan 04, 2014 | LG Washing Machines
During the first cycle of quick 30 i.e.in wash cycle water flow is very slow & no sufficient water flows through the detergent drawer.After some time it throws out water & both prewash n crease...
Remove the inlet water hoses to the washer and check the screens going in the ports for buildup and verify good flow coming out of hoses into a pail
Jan 28, 2011 | Washing Machines
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
97 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
