Question about Samsung BD-F5700 - Blu-ray disc player - Ethernet, Wi-Fi
Internet will not connect
I have updated the firmware and it will still not connect to the internet
What to do when security light is orange?
Reboot
  • The most basic way to attempt to fix a router problem is to reboot the device. This is accomplished by unplugging the powericon1.png cord, waiting for a minute and then plugging the power connector back in. If the orange light continues to blink, you will have to update its firmware.
Download New Firmware
  • Even though the wireless router is malfunctioning, downloading new firmware is possible by disconnecting the malfunctioning Linksys device from the Internet connection in the wall, then using that jack to plug your machine directly to the Internet. If this is not possible, use another computericon1.png that can connect to the Internet. You can download a firmware update directly from Linksys (see Resources).
Install New Firmware
  • Once you have the firmware update available on the computer affected by the malfunctioning router, open the file and follow the instructions to upgrade the devices firmware.
May 11, 2014 | Linksys Wireless-N WRT150N Router
Firmware update for Hitachi 51F59 51 in. HDTV Television
You need to set up the wireless internet connection in the TV to connect to a wireless router and then the TV will download the firmware update over the internet.
Dec 17, 2012 | Hitachi 51F59 51" HDTV Projection...
Clearos won't recognise the Sony DDU1615 with gys4 firmware.
yeah if you have its network cable you connect it to the computer and you update the firmware but you must be having internet connection and the latest firmware is there
Jul 19, 2012 | ASUS Pundit P1-PH1 Barebone
Just stopped screen froze
You can try a firmware upgrade. you can get the firmware from the manufacturer websight
If your high-def disc player has an Ethernet port, connecting it directly to the Internet is the most streamlined way to check for and install updates-though this requires that you connect an Ethernet cable from your Internet connection to your high-def movie player, which may prove difficult depending on your setup. Since every player is different, refer to your owners' manual for instructions on how to connect your player to the internet and how to update the firmware. With some players, you may have to power cycle the player after changing network settings before you can download firmware.
Jun 22, 2011 | Haier BDP100 Player
My links wireless g router will not stay connected to my house internet I must unplug it 20 times a day ill connect for ten mins then say limited access n not connect
Update the Firmware to your router to do that do the following. 1.In your address bar on your browser erase address. 2.Type in 192.168.2.1 3.The tabs to the left you will see firmware update click it and it will automatically look for updated firmware. If this does not help you can download the firmware from the direct website here is the website.
http://en-us-support.belkin.com/app/answers/detail/a_id/299/~/f5d7230-4-wireless-g-router---firmware-update
Feb 15, 2011 | Linksys Computers & Internet
How to get update for my WII?
The firmware for the Wii can be updated via the internet if you have a wireless router connected to the internet. The instruction manual expains how to connect the Wii to the internet.
Some newer games also include firmware updates.
Feb 14, 2011 | Nintendo Wii Console
Is it normal that when you r updating the firmware of it,much of time is needed?..the MB is increasing while updating
Usually firmware update takes much time depending on the speed of the Internet connection which you have.
First nokia updater have to be downloaded and when you try updating your mobile firmware then the nokia updator downloads the necessary update files from internet which takes again some time. After the firmware download then actual firmware updation happens. This will take some minutes.
Please note that interruption in firmware update may make your mobile unusable. Then you have to make a service call if anything happens like that. so perform firmware update with a high speed Internet connection and have UPS for your system.
I hope this is helpful to you.
Thanks
Mar 07, 2010 | Nokia N97 mini Smartphone
Playstation 3 disconnecting from wireless gaming
Linksys loves to ship their routers with out-dated firmware. If you haven't updated the firmware of your router, that would be the first thing I'd do. From what I've read about routers and PS3, a lot of routers had trouble when they came out but had firmware updates to resolve the problem.
You'll need to go to the below link and select your version to get firmware downloads specific to your Model router and version number. The version number is listed on the bottom of your router next to the model.
http://www.linksysbycisco.com/US/en/support/WRT54GS/download
Be sure to read up on how to update the firmware and be sure you only update the firmware from a computer connected via WIRED connection to the router. Doing it wirelessly will cause disconnection from the router mid update and will cause your router to become a paper-weight!
http://www.linksysbycisco.com/static/us/Learning-Center/
The above link is a good website to find out a lot of information about Linksys routers and how to secure/update/configure them.
Mar 04, 2009 | Linksys Wireless-G WRT54G Router
My Belkin F5D8053 is working in low strength
If you're encountering a very internet connection on your router, this is can be a problem with either the internet connection from your modem or the firmware of the router should be updated, first thing that you can try is to update the firmware of the firmware of the router, you can download the latest firmware of it from Belkin web site then after that observe the connection if you still have a slow internet using the router , Try to check now the internet from your modem by connecting a computer directly to your modem and if you still have the same problem internet connection from your ISP is the problem so you can contact them about that..........
Nov 11, 2008 | Belkin Wireless-N Wireless Router with...
Centrios internet radio gives dhcp timeout
This is likely because out of the box, the firmware for this unit doesn't support WPA2 and even certain variants of WPA. I recommend: configure router for WEP or even open (i.e. unencrypted) connection, connect unit, go to setup/update firmware and let it update from network, power cycle, reconfigure your router for WPA or WPA2 security, attempt to reconnect unit to wifi. The updated firmware supports more formats and may allow your new router's config to work. You can also try doing the firmware update over the wired LAN port. Hope this helps.
Sep 27, 2008 | Computers & Internet
Samsung BD-F5700 - Blu-ray disc player - Ethernet, Wi-Fi Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
