Question about Kenneth Cole Kc9110 Touch Mens Watch
Set digital time for kc9110
How can I set time in digital
How do I set the right time on my Casio 5208 aq-s800w watch
All you have to do is to set the digital time.After pressing the upper left button for 2-3 seconds the display digits start to flash.By pressing lower left button (MODE) once at a time and by using the left side buttons, you can set the right time,date etc.When finished press upper left button again to complete setting.Automatically the hour and minute hands will be set to the correct time following the digital time.
Mar 19, 2016 | Casio Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
I can't get the analog time on kennth Cole kc9110 watch after changing battery the digital part in running fine please help thank you
With this type of dual display watch, the two 'mechanisms' are often independant with their own batteries. It's quite possible that the battery for the analogue display has been missed - often they are underneath the battery for the digital display with an insulating cover to isolate the batteries from each other. Sometimes it's even necessary to remove the digital module to get to the analogue module. Obviously, you would need some experience of dismantling watches (and to be very careful) to sort this out. If you don't feel confident, and you value the watch, take it to a professional.
Jul 11, 2015 | Watches
Kenneth cole band replacement for kc 3903
please contact
aftersale@carmenco.com
thank you 9k=
May 31, 2014 | Kenneth Cole Kc9110 Touch Mens Watch
Waveceptor 3310 Frozen "H-S ET"
You must set the digital time as well.Analog time (hands) follows digital time.At first press button A.If digital time is according to analog time ok.If not you have to follow "H SET" (hour setting) procedure.
May 01, 2014 | Casio Watches
I want to set time of my KC 9110
Go here and see if this helps. It's a 90 page .pdf file. If it's what you need, you can save it to your computer.
http://www.nowatime.dk/app/doc/presse_77338808.pdf
Mar 28, 2014 | Kenneth Cole Kc9110 Touch Mens Watch
Kc9110
not able to know where is the button to adjust digital time n date
Jun 16, 2013 | Kenneth Cole Kc9110 Touch Mens Watch
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Kenneth Cole Kc9110 Touch Mens Watch Logo
    Top Kenneth Cole Watches Experts
    Jimmy Accardi
    Gary Nitowski
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
