Question about Toshiba Televison & Video
Toshiba tube tv display doesnt show
I bought a toshiba tv from my friend who needed money and everything was working just fine until i moved it, i think that I broke something or jiggled something inside and now the picture and sound work great but the display for the channel, volume, and menu doesnt show on the screen anymore.  So is there a way i can just easily fix this or does anybody have any kind of information of what the menu would show because i just installed cable in my home and need to get my menu to pop up so i can auto program my channels.  Any help would be greatly appreciated!
    President:
  • 1,348 Answers
When you unplugged it,it reset the clock.you need to set the clock.
on the remote play with the input,menu and display buttons until settings come up.one the date and time is set,probably ok.the best thing is to see if your friend has the manual.there are literally hundreds of different toshiba t.v. alone
Posted on May 22, 2009
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Any television remote will give full access to the television functions. The remote must be specific to that television. Google
make model replacement remote
There are original ones on ebay, plus companies that sell remotes that are an exact copy. The CT90326 may be for another Toshiba model, or of course it may be faulty.
Then we have the remote on the cable or satellite unit. That gives full command of the unit functions, but BASIC control of the television, normally On, Off, Channel Up and down to allow access to DVD or similar and Volume Up and Down. Everything else is done from the TV Remote.
To get the cable remote to make that happen, you Google
Toshiba Remote Codes
and run through them all until a selected code allows you to switch the television on and off.
Sep 25, 2017 | Toshiba Televison & Video
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Problems installing Toshiba RDXV59DTKB Freeview+ Hard Drive DVD
Two things, I was using a flaky budget=price SCART cable which caused a colour probolem. A techie friend said to view on AV rather than TV, which worked.
Jan 08, 2010 | Televison & Video
1999 toshiba rear projection tv blinking red light after moving
this might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Dec 25, 2008 | Toshiba 50H81 50" Rear Projection...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba 53AX61/ have sound no picture
I have the same problem with the same Toshiba 53ax61 the picture does not work anyone,
Please email me at skyhawkbasketball@hotmail.com
Oct 09, 2007 | Toshiba 53AX61 53" Rear Projection...
System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Apr 22, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
