Question about FoodSaver V2222 Vacuum Food Sealer
My foodsaver v2222 vacuum sealer will not vacuum and seal without having to push the vacuum/seal button and then pushing the seal button
When I push the vacuum/seal button I still have to push the seal button for the bag to seal.
3 Suggested Answers
  • 9633 Answers
SOURCE: foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Posted on Jun 07, 2014
Tried the recommendation above, even have let it air dry for more than an hour, there is nothing moist around the three contacts. I, of course am in the middle of a huge project!
Posted on May 28, 2016
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
Foodsaver vacuum sealer tray full light
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
Mar 11, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
It won't seal it doesn't get hot it vacuums ok
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
Jan 19, 2014 | FoodSaver V2222 Vacuum Food Sealer
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
FoodSaver V2222 Vacuum Food Sealer Logo
48 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
