Question about Coby Televison & Video
Lost the Screws To my Coby 55 inch Base Stand
I need to know what kind of screws I can use to mount my Coby 55 Inch LED tv back on it base stand.
4 Suggested Answers
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
SD Tech
  • 14553 Answers
SOURCE: i have a 60 inch LG Plasma tv and the base stand need screws need to know what size screws
See a lot of this kind of problem: easiest way is with the model number call the LG customer service number and get the bolt info for number and thread type---IN ALMOST EVERY CASE THE BOLTS WILL BE STANDARD FINE THREAD AND AVAILABLE AT MOST PLACES LIKE HOME DEPOT.
Posted on Apr 16, 2012
bugoy31
  • 1238 Answers
SOURCE: SCREW SIZE FOR LG 42 INCH SCREEN STAND
It is usually indicates on manual..
if you don't have manual try to go to retrevo.com..
Usually the common size 1/2 inch wood screw..
Posted on Jun 06, 2012
Where can I find the piece that holds the tv for vs91350-01
Walmart and others have the universal "jimmy stand" for about 90 bucks. This will mount to the TV (on the back like a wall mount) but also includes a base so you can simply set it on a table.
http://www.walmart.com/ip/ShopJimmy-sj-Stand-3755BB-Universal-TV-Stand-Base-Plus-Wall-Mount-for-37-inch-55-inch-Flat-Screen/36774428
or search
sj-Stand-3755BB
Oct 26, 2014 | Televison & Video
Can't figure out how to put the base on a 55 inch flatscreen colby tv
Usually the base is attached to the back of the TV by screws. The standard mounting method is widely used
Dec 15, 2012 | Audio Players & Recorders
I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
Nov 02, 2011 | Toshiba Televison & Video
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How do we remove the base stand from the lcd-32xr8da so we can wall mount it
There are 4 screws connecting the base to the tv on the 40xbr. didnt check to see if its the same with the 32 inch. the base connects to the tv (on the bigger one) via two prongs both with 2 screws in it, look for the screws and you're all set.
Feb 04, 2010 | Sanyo Televison & Video
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I need to remove the base from my 42 inch plasma TV to mount it onto a TV stand. How do you remove the base?
Good Day;
The base is attached by four, inset, allen screws on the back of the unit, bottom. The 'key' word is INSET (recessed).
Good Luck, Day, Big Irish.
Jun 18, 2008 | Akai Televison & Video
Toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Feb 24, 2008 | Televison & Video
Televison & Video Logo
71 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
