Tevion tdr930 I have a TDR930 DVD recorder and want to know if this receives digital signal as I have obviously problem tuning unit to to record Nicholas Velios
  • Televison & ... Master
  • 5,339 Answers
The TDR930 does not have a digital tuner. It handles the PAL and NTSC video signals. You need to connect it to a set top box and then record on the Line In (composite video) input. The set top box could be a cable, satellite or digital-to-analog OTA converter. Since the DVD recorder can't record HD signal, the regular SD output converter box connected to an antenna will be good.
I wish that I had better news for you.
Posted on Jan 04, 2014
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: How can I find the
Try to check this link.http://www.manualsonline.com/ .hopping that this may help you
Posted on Jul 11, 2011
I am unable to auto tune my Tevion DVD Recorder
If the recorder is old the analogue/digital change is screwing it up. It isn't the TV that is the problem, it is the received signals, but the problem is the same.
Dec 28, 2013 | Tevion AP-DVR18 DVD Recorder
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
Jul 11, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
I don't know how to tune the digital channels in my vcr. I can automatically tune channel 2, 9, 10, etc but not 7mate, 99Go etc
If your unit does not state DVB anywhere, either in the manual, or on the unit itself, and there are no options to tune in digital services via the menu on screen (as well as no EPG), chances are the tuner in it is analogue only, hence why you cannot tune digital channels in it. To receive all SD/HD digital channels, you would need to connect an external set top box to the recorder's AV inputs, and record/view them that way. (Set top boxes are cheaper than upgrading TVs and DVD equipment in many cases).
The only positive point here is it didn't cost you a workshop repair fee or a new unit - the user manual as a pdf for this model is available on FixYa if needed.
Jun 12, 2011 | LG RC389H DVD/VHS Recorder
How do I , or in fact can I, tune the DVD recorder such that it can see the digital TV stations - all I get at the moment is analogue channels
can you receive digital channels through your tv (if it is a DAB TV)? The reason i ask is that you may not have a strong enough signal to receive digital channels. Try taking the dvd recorder to a friends house and plug it in there to see if it will tunethe stations in. IF it does try it back at yoursto see if it will pick up the channels if it breaks up the picture then you need to upgrade your ariel
Mar 11, 2011 | LG RHT397H DVD Recorder
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
User guide for Tevion PVR801 Digital Television Recorder
i am lookig for a user manuel for a tevion PVR recorder
Oct 05, 2010 | Audio Players & Recorders
LG RH277H aerial reception
relocate antenna or buy hdtv antenna. use hdmi cable for the dvd rec to tv. adjust dvd rec input source to hdmi.
Jun 12, 2017 | Televison & Video
Wanting to know how to save past recordings onto cd as the receiver is about to be replaced again!!
There are devices that will convert the video/audio outputs available from the back of the Dish receivers into the format needed to input to a PC (and maybe Mac too) but beyond that, you would need either an external DVD recorder or a VCR that has lived past its time.
The Tevion model we have is currently offered on eBay for a starting bid of $10 US:
Tevion DVD Maker
May 17, 2009 | DISH Network IR Remote Control
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
