Philips tv wont turn on
Philips lcd model 47PFL5522D/05 stuck on Digital TV, wont let me change source or channels by remote or manually on tv remote works fine cause switches TV off and on, and puts volume up and down, but when pressing source or any other button, an X appears in the corner. please help, cheers
  • 87 Answers
SOURCE: Tv not changing channels.
This likely has a bad main board.
Posted on Oct 23, 2007
SOURCE: TV controls not working
ARGOS SELL SPARES FOR ALL REMOTE CONTROL DEVICES ON THE ARGOS SPARES SITE. PRICEY BUT WORTH IT!
Posted on Dec 08, 2007
  • 5 Answers
SOURCE: LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Posted on Jan 18, 2008
  • 3 Answers
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
SOURCE: Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Posted on Apr 19, 2008
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Philips remote instructions
Scan button? Should it be the source button? Look for box with an arrow/line symbol
Dec 05, 2013 | Televison & Video
Philips 42PFL5522D/05
It sounds that the fault is with its main board. It will be best to contact the authorized service center for Philips in this case.
Oct 06, 2013 | Televison & Video
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
I changed the cabling between my Phillips tv and set-top box a few times and I lost the signal. The signal is from UPC, it's piped tv. They said to locate the av channel on the tv and this would restore...
The only way to change the source for the 28PW8608/05 is to use the remote. On the original remote, just below and to the left of the power button is the button you need. The image on it is a square with an arrow going into the square from one side. The inputs should go TV, EXT1, EXT2, (EXT3 on some models), Front). Depending on the set top box, you may need to enter the setup menu and set the digital source for the input (Press together Fast Rewind and Stop > Setup > Digital Source) or the decorder (next option in Setup).
If you do not have the original remote, you will need universal remote with an input or source button and to find the code that matches the function. Some codes may only operate the basic functions. (The lowest end universal remotes often lack this feature.) A universal remote that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
Dec 29, 2010 | Philips 32PW6506 32" TV
I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
Philips Flat TV locks up on one channel and won't change
hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
Jul 25, 2009 | Philips Televison & Video
Tune 14 inch TV on remote ie BBC1 on No 1 thro to No5.
here is a link to thhttp://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=TV_CONVENTIONAL_CA&sct=COMBI_TV_SU&session=20090102155334_65.38.34.98&grp=TV_GR&ctn=14PV182/05&mid=Link_UserManuals&hlt=Link_UserManualse manual
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
