Question about Dodge 1997 Ram 1500
1997 dodge 1500 truck it for a time then souds like it running out of gas
It starts up good you drive it a few milles then starts skiping and sucking air like its running out of gas then after sets awhile starts and does the same thing
  • 45 Answers
A clogged fuel filter would cause this. If a replacement filter doesn't cure the problem, it would be a good idea to check the fuel pressure at the fuel rail. A bad fuel pump will cause the same symptom. Fuel pump failures are quite common in 1990s Dodge products.
Posted on Jan 25, 2014
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
Feb 04, 2016 | 1997 GMC Sierra
1997 dogde ram 1500 5.2 magnum starts and idlesbut makes a loud air sucking noise and just starts chugging when i try to accelerate.this happened suddenly while on the highway. after sitting for a whi
You have a bad valley pan gasket, not very expensive to fix at all, it is located under the intake manifold, happened to me and almost everyone I know that has this truck, goodluck
Jan 06, 2013 | 1997 Dodge Ram 1500 Club Cab
I have a 1997 dodge avenger es 2.5 liter here's
Check the vacuum line on the fuel pressure regulator for any sign of gas being sucked into the line. A failed regulator will let extra gas get into the engine. If it's okay, have the fuel pressure checked. That's sure a lot of gas, way too much for the engine. Good luck.
Jan 27, 2012 | 1997 Dodge Avenger
Does a 1997 dodge 1500 have a inline fuel filter?
Its already in the fuel pump module.Sounds like you might have a security system problem with the ignition switch.If you have a newer key try it.
Jan 26, 2012 | Dodge Cars & Trucks
I have 97 dodge ram 1500. Once tha truck reaches operating temp. it will stall at idle. Some times you drive it and it runs fine then you stop at a store get a snack and then it wont start with out pumping...
A few things actually lol. How long since its last tune up? A dirty air filter, worn spark plugs and wires and cap and rotor can cause a poor idle and stalling. Not to mention a dirty fuel filter. The fuel filter is in the gas tank unfortunatlly :(
Try giving it a basic tune up " about 45 dollars" and see if that helps. Good luck.
Jun 11, 2010 | 1997 Dodge Ram 1500 Club Cab
I have a 2005 Dodge Ram hemi 1500 4x4. would not start.
I suspect the gas tank has some crud on the bottom that gets sucked in when level is very low and/or truck is parked on an incline.Suggest installing in-line fuel filter, let gas level get nearly empty and then check in-line filter. If there's junk in the filter, tank needs to be cleaned. Or just keep the tank a quarter full until it can be cleaned.
Apr 05, 2017 | Dodge Ram 1500 Cars & Trucks
I have a 1997 Dodge Ram 1500. When I first get in the truck and drive it, the first few times I step on the brake pedal it locks up the front wheels. Can anyone tell me what is going on or what I need to...
Vehicles of today are no longerstart and go. The systems all need time to Ck, recheck and make adjustments. The AbS system does a self check the first few minutes after the vehicle is started. You should be able to hear all the clicking going on. So, consider that before taking it in to the dealer or a shop. For sure, make sure the rear brakes are adjusted properly. Good Luck
Nov 12, 2009 | 1997 Dodge Ram 1500 Club Cab
Car has half tank of gas acts like its run out of gas until more
is there a engine light on? take the gas cap of and see if it does better you might have a plugged vent
Oct 28, 2009 | 1997 Dodge Ram 1500 Club Cab
My 4.7 2002 dodge 1500 will not start
i purchased a new timing chain set and the cam pickup was bad on the new cam gear and we had a no start problem. i took the valve covers back off put the old gear on the cam and it started. BUT be careful if u do that you have to wedge the timing chains apart before you remove that gear so the hyd adjusters do not over expand. 4.7 dodge engines **** BIg they made them trying to save gas but the parts and repair over-ride any gas saving i got.
May 12, 2009 | 2000 Dodge Durango
Sometime works other 50/50 won't idle
Honestly, I would say its your Mass airflow sensor. Sounds like your truck is sucking either not enough, or too much for the air/fuel mixture to compensate. Thats what it sounds like to me. I would replace that, or even clean it. If you take it out, and clean it up real good with some alcohol, you might catch a break as well. Hope all goes well.
Mar 15, 2009 | 1997 Dodge Ram 1500 Club Cab
Dodge 1997 Ram 1500 Logo
69 people viewed this question
Top Dodge Audio Players & Recorders Experts
Betty Pearl
Betty Pearl
Level 1 Expert
Jeff Brewster
Jeff Brewster
_-__-___-_
_-__-___-_
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
