Question about Music
Digitech/model ELMTV-01 I bought your product and it said that if I email you, i could get a manual on how best to operate my purchase!
Im looking for a manual for a digitech gsp 2101 studio tube preamp processor the standard model not the artist model??
Find one here: http://www.manualslib.com/manual/380759/Digitech-Gsp2101.html
Mar 07, 2015 | Music
RP 100
I am assuming you are referring to the tuning aspect of the processor. Factory default is "A" but you should be able to change that via the Parameter1 knob. Or someone did change it and saved that alternate, if you bought it used.
If you do not have a manual, here is a link to the US version, which was designated as 100 A
http://www.digitech.com/en-US/products/rp100a
Mar 29, 2012 | Music
Download manual free
The VocalistPro Live4 page has a link to the manual on the right side of the page: http://www.vocalistpro.com/product.php?name=Live4 . The direct link to the English version of the manual is http://www.vocalistpro.com/downloads/products/6/VL4_manual_en.pdf .
I hope this helps.
Oct 27, 2011 | Digi-Tech Digitech Vocalist Live 4...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I need instrution manual for a digitec rp100a guitar effect
The manual you are looking for can be found right here:
ftp://ftp.digitech.com/pub/PDFs/Manuals/RP100A%20Manual%2018-1867V-A.pdf
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 22, 2010 | DIGITECH Guitar Effects Model No Ddm
Expression pedal wont work
Here is a link with a source for the manual on the right of the page:http://www.digitech.com/products/Bass/bp200.php Further information can be found at support at the top of the page.
Mar 20, 2010 | Music
Hi! Im looking for the service manual or schematic for the Digitech Valve Fx guitar eff.proc. The unit can turn on, and in bypass mode has a clear sound, but in normal operation has terrybly noisy, It...
hello,
can be too late but one never knows:
http://mesnotices.fr/314159.php?k=b7e42b97c5e87d24451de2516f66eef9&ID=18334&q=DIGITECH%20VALVEFX
you must simply answer the questions to be able to download.
Philippe to France
Jun 10, 2009 | Digi-Tech Digitech Vocalist Live 4...
Music Logo
67 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
