Question about Gateway FPD1975W 19" LCD Monitor
When connect ps3 to monitor it turns on then goes black then on and off
  • 21 Answers
If you try the monitor elsewhere and still does that, there are chances that the hight voltage work for few seconde then stop.
Most monitor experience this with age, I use to open the monitor and look for condenser that have the top carved, not flat anymore.
this mean that the condenser dry and made internal gaz.
Those should be all replaced. 2 time over 3 it does fix this issue.
then if you try you monitor on a computer and it does work correctly, then it would be the PS3 , I suggest trying to unplug the PS3 for a 30 sec then try rebooting it. (did happend to me once)
Posted on Jan 04, 2014
PS3 asus mx279h hdmi black screen
When you turn on the PS3 hold the power button and it should do a couple of beeps this means it has reset the video output and should work :)
Jan 11, 2014 | ASUS Computers & Internet
I just got a used 2 port KVMDVI switch to run my PC and PS3 simultaneously. The PC view is working fine but when I switch to the PS3 I get a black & brown screen. (I know it is getting a signal because...
The SC switch is a Secure Switch for Goverment applications and or Military Ops, PS3 is therefore not a supported target. First of all because the Interface is most like HDMI owhich your switch doesn't support, the usage of adaptors are not going to work on that kind of switches.
I hope that helps.
Jan 15, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Screen goes black and no backlite when connected
Please reduce the resolution/ Frequency of your Display Card in system and see whether you can see some thing. Else connect this monitor to another system with low resolution. Let me know your feedback.
Mar 18, 2008 | Samsung 710V 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
