Question about Refrigerators
Not freezing lots of ice at back left of freezer but food is slowly defrosting
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
SOURCE: freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Posted on Dec 16, 2009
SOURCE: hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Posted on Aug 05, 2011
Are ice maker stopped working, so we need to reprogram it
*Check your warranty. You should call vendor for service.
*** The following is for information only.***
* I've had this problem a lot with my old fridge. Water line works but no ice.
* Check if the "Ice Full" leaver is in the down (no ice) position. Some ice makers will lock the leaver (a stiff wire) in the full position to manually shut off ice maker. Make sure it swings up and down when ice tray is empty.
* Sometimes when the tray is left full of ice for a week or more then the tube feeding water will freeze up. Defrosting the freezer on a regular basis will help. A quick fix is to pour warm water in the ice maker section (where the ice is formed). This will help melt the clogged pipe and also make some ice while your waiting. You may have to do this several times. But at least you have ice.
* This (freezing up) may also be caused by the freezer set too cold. The temperature dial should be in the middle. But turning it colder and colder over time will cause ice to build up and prevent foods from freezing properly (thus turning the dial down colder.) Once your maxed out on the dial. You will find the freezer gets warm and things get covered in frost crystals.
* Transfer food to another refrigerator and perform a complete defrost by leaving it unplugged and the door open (freezer section).
* Frequently check and dump water at bottom of fridge. Clean the dust on coils while down there.
* A fan blowing into the freezer section helps. (Do NOT use a heated fan as it will warp the plastic and overpressure the refrigerate.)
* Once defrosted (+4 hours). Power up the freezer and set the temperature dial to mid point and the freezer diverter to middle or normal setting. Don't put the food back in yet. Wait till the freezer gets down to normal freeze temp (about 0 to 10F)
* Move freezer back in place (if you moved it to access plug) then slowly put back the food. Try not to cram stuff in. Leave space for air to flow freely around items.
* Final, Call for service anyway and have them perform yearly service. Check your warranty.
Aloha, ukeboy57
Mar 12, 2018 | Refrigerators
Whirlpool fridge WF258 freezer works perfectly; but fridge is in room temp, not working at all,light is ok
Damper door between freezer and fresh food not opening or build up of ice not letting cold air in fresh food side may have a defrost problem if you have a lot of ice on back wall of freezer
Nov 20, 2016 | Whirlpool Refrigerators
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
Maytag Performa fridge has stopped making ice -- I changed the water filter to make sure that wasn't the problem. The water in the door works fine and there is plenty of pressure in the water line but the...
First, I'm not a Maytag tech.
Check your warranty. You should call Maytag/Sears for service.
Aloha, ukeboy57
Feb 20, 2018 | Maytag MTB1504A Top Freezer Refrigerator
Ice has accumulated at the bottom, food at top is slowly defrosting
I believe that the defrost system has malfunctioned. There is a timer that cycles the automatic defrost. The timer shuts off the freezer and turns on a heating element. Then it will cycle back to freezing. If anything goes out in this system the unit will not defrost. over time the cooling fins and below will fill up with ice and the fan can no longer recirculate air so the bottom becomes ice and the top warms up...
Sep 20, 2010 | Frigidaire Freezers
Kenmore 253.56953601 freezer isnt working properly. food is slowly thawing and ice maker stopped working
I think you have a defrost problem. Look at the inside lower back panel of your freezer. If I'm correct, you will see ice built up. You can take the panel out, defrost with a blow dryer. (After defrosting you can check your heaters. I'm sure you have a bad heater) You can put panel back in and turn the unit back on. It will run ok for around 3 days, This will give you time to repair or get repaired without loosing you food.
Please rate solution
Oct 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by Side not getting cold enough to freeze food.
Evap fan...cond..fan ...do they turn.....seems like a comp...problem...does the evap ice up...?
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
The freezer fan is running and the freezer is cold, but the fridge is warm
Your defrost systems needs repair.
Set all controls back to mid-range positions.
Open the fresh food door and look up underneath the control panel for a small round hole. About the size of a dime. Insert a flat blade scredriver in the hole and slowly turn clockwise until you hear a click and the compressor shuts off.
Then listen closely for defrosting sounds in the freezer. ie,ice cracking, water dripping,water sizzling.
If you hear these sounds and notice the ice starting to melt, replace the defrost timer in the control panel.If this does not happen replace the defrost thermostat and heater in the freezer.
You will also have to remove the panel from the back wall in the freezer then use a hair dryer to finish thawing the ice in the freezer.
May 03, 2009 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
