Question about Pioneer VSX-818V-K Receiver
No sound from rt front speaker on pioneer vsx 5231 system
techman
  • 3130 Answers
SOURCE: static and crackling sounds
Sorry to burst your bubble my freind but things do wear out as you had plenty of life out of this unit.. Your problem is a transistor or a driver IC is breaking down under a load and heat and will get worse to where you wont be able to use the unit.. It will probable cost you in a range of 200 bucks or .more!as there is no quick fix for a solid state unit that has no user serviceable parts inside. Its just not replacing the bad part , its the hooking up to the load resistors then seeing that several other parts are not up par and having to start rebuilding the amp statges of your reciver.. If its more then 8 years old Time to landfill it and get a new one .. Put it to rest. It dosent owe you anything as its been loyal to you all these years!! Good Luck
Posted on Jul 27, 2006
  • 63 Answers
SOURCE: pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Posted on Aug 03, 2007
SOURCE: pioneer VSX-D503S receiver-no sound coming
it might need to be rregrounded
Posted on May 27, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
robotek
  • 1512 Answers
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Posted on Nov 08, 2008
Pioneer VSX-D307 has no sound from right front speaker.
Did you connect a known good speaker to the amplifier's right front output connections? Make sure you also have known good wires for the front right as well. Make sure balance control is set to the middle and not just to the left.
Aug 22, 2016 | Pioneer VSX-D307 Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
Pioneer VSX-818V-K Receiver Logo
67 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
