Rca entertainment series unusable signal
I got a new philips dvd player and im trying to hook it up and when i switch the tv over to play the dvd player the screen is black and says unusable signal what could be wrong?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
I think your rca cord is not functional. replace it with another one or fix the connections of your cord.
Posted on Jan 04, 2014
Zackd9184
  • 56 Answers
SOURCE: Magnavox Blu-ray hook-up to RCA Entertainment series
Blu Ray is not made for analog tv's it's only made for the new tv's that have the HDTV logo on them it will not work on older tv's
Posted on Nov 28, 2008
chessmaster2
  • 160 Answers
SOURCE: Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Posted on Dec 01, 2008
  • 12 Answers
SOURCE: Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
Posted on May 10, 2009
SOURCE: DVD only plays in black and white on my Toshiba 27D46 TV
Check on the dvd menu for the video format maybe that´s the problem
Posted on May 16, 2009
SOURCE: RCA TV
my tv shows a black screen with words saying...UNUSABLE SIGNAL
Posted on Jan 12, 2010
I have an rca tv that im trying to hook up to a dvd player and I can't get a signal or channel to work. I don't have a remote but the menu button works. what channel should it be on to play dvds
depend on tv input; if it's only one rca input mean is composite video; if are 3 rca input mean rgb video. so from dvd you need a scart to composite or rgb. on tv usually is AV or AUX channell. try to find a universal remote to select properly the channel. bye
May 23, 2014 | Televison & Video
Unusable signal
This is a resolution mismatch problem. One of the devices will not accept the resolution of the other. Try another type of connection or try another input.
Apr 13, 2014 | Sony DVP-SR200P DVD Player
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Orion Television problem
Hi. dvd pixelates when playing. have cleaned lens but still pixelates when playing. thanks.
Dec 27, 2007 | Televison & Video
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
