Question about Magic Chef MCD990R Microwave Oven
Magic chef microwave buttons will not work but microwave is on
Our camper magic chef microwave is on but the buttons are not working. We have check to fuse and it is good.
    Problem Solver:
  • 5 Answers
Its a connection problem probally from a bump while driving the camper - you can dismantle the microwave yourself from the back and reconnect the jared wiring, or just replace it with an industrial one that can handle the camper abuse.
Posted on Jan 05, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
dmftrucker
  • 1922 Answers
SOURCE: Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Posted on Sep 27, 2009
Testimonial: "Thanks for the help! I'll try it and let you know."
localwonder
  • 6784 Answers
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Posted on Dec 23, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
SOURCE: magic chef over-the-range microwave shut off
I have a Magic Chef Microwave Model MC0153UB that is shutting itself off while cooking. I noticed before this, the light under the microwave blew during a storm. Do you have any suggestions?
Posted on Jul 22, 2010
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
Magic Chef Microwave has stopped working. None of the buttons work. It's showing random numbers when you plug it in. I tried a different outlet and it gave me different numbers.
Try unplugging it for 24 hours. Plug it back in and see if this helped. If it's still the same, it needs a new control PCB (printed circuit board).
Oct 16, 2013 | Magic Chef Mcd1811st 1.8 Cubic-ft,...
My magic chef microwaves is lock. how do i unlock it
On many Magic Chef models, press the Help button to bring up the menu. Choose the number for Child Lock (I think it's #1), then choose 2 to turn Child Lock off.
Dec 02, 2010 | Magic Chef MCM660A Microwave Oven
Ours magic chef 900W MCD990ARB completely stopped. We have it in our camper and everything on that end is fine. Checked the micro in a different outlet, still no go. Any suggestions?
Well if you are lucky it is an internal fuse. Open it up and look somewhere near where the cord comes into the unit. If it is not the fuse then I suggest you replace the whole thing.
I recently was attempting to repair one. The part cost $93, a new microwave costs that or less.
May 11, 2010 | Magic Chef MCD990W Microwave Oven
No heat on magic chef microwave
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
I was making popcorn and the microwave just died
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jun 07, 2009 | Magic Chef CMV1000B Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD990R Microwave Oven Logo
179 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
