Question about Apple iMac G5 Desktop
My Apple IMac G5, 2GHz 512 MD DDR SDRAM (Sr.No. W85399C8SDY)developed a couple of white lines on the screen a few months ago. These have now spread to cover almost the entire LCD display. What is the likely problem and how can it be fixed?
  • 221 Answers
Hi, it seems like a motherboard problem (hardware), you will probably need to bring the mac to an AASP. Before, you can try the Apple Hardware Test, or resetting the PRAM (Hold the cmd, alt, p and r keys)
Posted on May 29, 2009
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
Dec 29, 2010 | Dell Inspiron 1525 Notebook
About 6 months ago there were 2 colored vertical lines on my desktop screen. I've been getting more lines every 2 or 3 weeks and now have a total of 18. The nearest Apple store said they can fix it no...
It should not affect the data on the hard drive but with all repairs such as this it always worth making sure you have your hard drive backed up. I had a similar problem with a imac a couple of years ago and the hard drive was fine when it came back. Hope this helps.
Nov 14, 2010 | Apple iMac G5 Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
White vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Dec 15, 2008 | Apple iMac G5 Desktop
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Can't get open office installed in my mac
Open Office has been slow to develop a full version for Mac. Try Neo Office instead as it has a fully Mac-compatible version. The Open Office for mac is expected in a couple of months.
Oct 02, 2008 | Apple iMac G4 Desktop
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Apple iMac G5 Desktop Logo
419 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
