Question about Bosch Tassimo TAS4511UC Coffee Maker
Spray nozzle red light - Bosch Tassimo TAS4511UC Coffee Maker
Clean throttle body on 2008 town and country 4.0 Liter
use stp carb and throttle body spray.. its a red white and black spray can with a small red hose attatched that is inserted in the spray nozzle to reach all the orfices and such..
Dec 27, 2013 | Cars & Trucks
The heated solutions only sprays out to the floor in a 3 inch area. It takes a long time to clean the floor with only 3 inches available. Are there some nozzles somewhere on the machine that I need to...
There are two nozzles (either red or white) on the unit located behind brush. Use an old toothbrush to clean them off and that should resolve the spray issue.
Nov 22, 2010 | Bissell 1699 ProHeat Clear View Upright...
My bissell proheat will not spray water or cleaner and the filter does not turn;
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!!
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Will spray from handtool but not from brush floor
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! e
Sep 05, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have 2 bissell pro x2's that are now both not spraying water
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! d
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920-E; No spray.
I have a similar problem and `phoned Bissell support. They told me that no spray is either a failed drive belt or a failed pump. I suggest you remove the belt access cover and see if the belt is intact; if so rotate the pump using finger pressure - it should rotate easily with no unusual noises.
If this is all OK, fill the bucket and the mix bottle with warm, clean water. Turn the machine on and with the handle upright press and hold the trigger for about 2 minutes. Hopefully you should see a spray and both the bucket and bottle will reduce in volume. If not you have either a blockage in one of the tubes, the trigger valve needs adjustment or, worst case, the pump has failed.
Hope this helps.
Jun 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell proheat 7 will not spray water or cleaner
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Jun 05, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My carpet cleaner will not spray. Maybe a little thru the tool but not enough pressure to SPRAY
p.s. Make sure you do give it about a minute after you turn it on before you try spraying. If the pump is not allowed sufficient time to prime, you may not get proper flow.
May 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
the water head are pluged use a tooth brush and some hot hot water and brush it on the tips until they are unpluged
May 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bosch Tassimo TAS4511UC Coffee Maker Logo
21 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
