Question about HP PSC 1315 All-In-One InkJet Printer
Hp psc printer paper feed is jammed with an piece of paper.
The hp psc 1315 picked up a loose piece of paper lying on the paper feed and it jammed up the paper. I can just see it, but there is no way to pull it back out.
Marvin Walker 770-442-3257
    Sergeant:
  • 199 Answers
The small gear located in the paper feed assambly is break or fail, need replacement parts to repair it.
Posted on May 22, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer will not grab the paper HP PSC 1315 All in one inkjet
Try using a cloth (not a paper towel) with some water on it and clean the feed rollers. Also no alcohol.
Jan 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
Will not print on command from computer
carefully check that their arent any tiny pieces of paper stuck in the feed mechanism.
Hope this helps
Feb 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Will not feed the paper.
it probably needs a roller assembly replaced
Jan 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP 1310 All-in-One
check inside for little extra pieces of paper
Apr 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 paper jam.
does it turn on or doesnt pick up the paper?
Oct 28, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
222 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
