Question about Canon imagePROGRAF® iPF8100 InkJet Printer
Disable ink level
Service menu
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
Low ink warning not right. ink is full. What to correct warning?
According to the information on the website, you should be able to press the Stop/Reset switch for about 5 seconds to disable ink level monitoring on the empty cartridge.
Feb 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
PRINTER PixmaMP 130
HI
You can try.
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
All best
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have Canon MP130 Printer. After deep clen error message Waste ink absorber is almost full - how do I fix it and where do I get new ink absorbers?
Here this step by step to resetting waste ink counter.
The waste ink pad is in the bottom of the printer.You need to disassembly the hole printer to find and change it.
Oct 09, 2009 | Canon PIXMA MP130 All-In-One InkJet...
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
Ink absorber is almost full....what should i do?
It sounds like we should follow the procedure suggested for the W7200. But how do we reset the waste ink counter on MP130?
Michel
Oct 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon printer
west is absorber is only the pad of thin ink absorbent material like fome when ink was charge that time some ink has been wested this wested ink has been stored or absorb this west ink pad. r u happy with this solution please tell
Oct 03, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon imagePROGRAF® iPF8100 InkJet Printer Logo
15 people viewed this question
old marine
old marine
