Question about Tablets & eReaders
Screen tablet gradson dropped tablet now all i see are lines screen did not break
I dropped my Winbook tablet and it charges but does not turn on
tablets are fragile items
dropping them generally breaks the screen or the internal workings
take it in for a diagnosis but be prepared to junk it
Jun 25, 2017 | Tablets & eReaders
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
Feb 03, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
My tablet has seemed to have lost all data there are lines of colrs only I did not drop in fact it had been sitting in its case for a week with no use drop either
If a power off/on or a full factory reset don't work, then you have a warranty claim to make!
Press down the Power button and tap Volume Up as you startup the Jazz and you should see the Android system recovery menu appear on your screen. Choose the `factory reset`. All data will be wiped, all settings erased - so back it up first!
Jan 03, 2015 | Jazz UltraTab Internet Tablet - Android...
Zeepad locked
Hello
This is a common problem with cracked screens, the digitizer breaks, which is the component that makes the device touchscreen. I might be wrong, but that seems to be the case.
Mar 18, 2014 | ZEEPAD VIA8650 Android 2.3 Tablet
Drop the tablet
The screen probably will have to be replaced but the fall may have caused internal damage so that even with a new screen the tablet may not work without further repair.
Dec 30, 2013 | Supersonic SC-91JB 9-inch Android 4.1...
I dropped my nook hd+ the very top of the screen is now pixelated with black,white and color lines. Can the screen be repaired.
Yes.. i use a very good step by step site to fix such issues. Even though i do it all day it helps to have it planed out like this.
http://www.ifixit.com/Guide/Nook+Tablet+Display+Replacement/11148
hope this helps
chad man
Nov 16, 2013 | Nook HD+
Kurio LCD screen broken
can the kurio 7 screen be fixed if i have broken ( line down the middle of screen and not geting anything picture wise)
Nov 08, 2012 | Techno Source Kurio Kids Tablet With...
I dropped my T4220 and now the screen is blank and its beeping. There are no visible cracks on the screen or the casing... The fan is on and nothing else :( Any help pls...
There could be anything from a wire off to a hair line crack on the mother board. If nothing much works apart from the fan, it is possible the mother board is now damaged.
Feb 15, 2011 | Fujitsu LifeBook T4220 Tablet PC
Tablets & eReaders Logo
52 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
