Question about NordicTrack Exercise & Fitness
Keypad not work touchpad
Key pad lights up but when you touch the key pad, numbers stay at zero
listeur
  • 88 Answers
SOURCE: keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Posted on Nov 24, 2007
  • 998 Answers
SOURCE: dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Posted on Oct 17, 2008
SOURCE: touch pad not working correctly
If u are having Synaptics Driver....then
check that Tapping is enabled...
follow steps to know that:
Open Control Panel..
Now Open Mouse
Now click on tab "Device Settings"
then Click on "Settings"
a new window popups
Click on "Tapping" which is listed on the corner of the window
Now after clicking on it...on the right...check that there is "Tapping Enabled or not"
if not...click on that White box...
and Apply
then ok
Done :)
_________________________________________________________________________________
Sorry 4 my english!
Posted on May 17, 2009
weblord
  • 507 Answers
SOURCE: emachines laptop touchpad diabled.what keys do i
there are no keys, it can only be enabled using the software that came with it.
Posted on Oct 20, 2009
  • 157 Answers
SOURCE: the touchpad of my laptop was being unlock. there
HELLO, THERE IS USUALLY A SWITCH NEAR THE TOUCH PAD.CLICK ON THAT SWITCH AND SEE WHAT HAPPEN
Posted on Nov 18, 2010
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Key pad is not working
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 11, 2012 | Electronics - Others
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Touch pad not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 04, 2012 | Computers & Internet
Emachines netbook unlock key pad
Key Pad or Touchpad? Is it that the mouse pointer is frozen and does not work? If so, look at the middle of the touchpad at the top of it and there might be a button there that lets you toggle the touchpad between locked and unlocked.
Sometimes there might be a set of keystrokes you will have to hit to lock or unlock the keypad. Most times you will have to Press and Hold the Alt, FN or Ctrl key then hit the key (most times one of the F1 thru F12 keys) that controls the keypad. The key that controls the keypad will have the icon of a finger inside or pointing at a square that represents the keypad. On one laptop recently that I worked on it was toggled by Pressing and Holding the ALT key then hit the F6 key. F6 had a finger pointing at a square area representing the touchpad.
Apr 07, 2012 | eMachines eMD620-5133 Notebook
My touch pad does hot work the message I get it can't find the toutch pad device
Hi
Press Fn key + F7 key (For Acer - Keypad Lock key) and open the keypad lock.
If not, try SYSTEM RESTORE, go to START ICON>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS DATE YOUR TOUCHPAD IS WORKING FINE.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 12, 2011 | Computers & Internet
My touch pad is not working before was ok but now i have to click to left botton for any things tanks
locate the FN key on the lower left side of the keypad,
next locate the touchpad key usually one of the F keys(F1-F12) press and hold the FN keys and the touchpad key, release them and check the touch pad.
PLEASE LEAVE COMMENTS.
Mar 28, 2010 | Acer Aspire 5610-4648 Notebook
Key board and touch pad do not work
Did it shut off on the keypad? Sometimes things are being so frustrating that we forget that the keypad has a shutoff that can get bumped. Make sure it's on.
Mar 30, 2009 | Acer Aspire 6930-6771 Laptop
Aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Oct 30, 2008 | Acer Aspire 5100 Notebook
Keyboard and touch pad locked
Nov 19, 2007 | Dell Latitude D800 Notebook
Exercise & Fitness Logo
14 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
