Question about Kenmore Kitchen Ranges
Error code - F30 - Kenmore Kitchen Ranges
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Model number?
Posted on Feb 18, 2014
Error Code E30
Hello tcavness609 - Are you certain the error code is F30? This manufacturer does not have a F30 error code for any washer. However, there is an error code F31 that indicates that the pressure senor is not communicating with the main control board. A professional will need to inspect the wiring between both parts and depending on the diagnoses either part will need replacing.
Dec 18, 2012 | Frigidaire Affinity ATF7000E Front Load...
F30 comes up and the drain basket is empty
F30/31 - Motor Error
If this error occurs then you should try to run the programme again, but a persistent problem will need to be looked at by a professional. A F30/31 error code can indicate a fault with the carbon brushes, drive belt, motor relay or PCB. You can buy spares for your Hotpoint washing machine at many places on the 'net, simply Google for it.
Nov 09, 2010 | Washing Machines
Kenmore elite 49962 washer error code f30
hi sir, please check the following link. it tells about cause of the problem[Error Code F30]. http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
kindly rate me.. thanks for using fixya..
Feb 11, 2010 | Kenmore 49972 Front Load Washer
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jan 16, 2010 | Kitchen Ranges
Kenmore HE2 Plus 110.47512600 Error Code F30 = Dispenser System Error. Have reset CCU multiple times. When cycle starts, dispenser motor runs for 3 minutes (~11 revolutions) then stops with F30 error
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2009 | Kenmore HE2 Plus Front Load Washer
F30 code
F30 = DISPENSER SYSTEM ERROR
You might have to replace the damaged one.Or in other words something that cannot be repaired.Well came across this info through other certified websites.good luck.hope this helps out.
Jan 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
90 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
