Question about Mtd Garden
Toro powershift 1028 snowblower starts but doesnt stay running
4 Suggested Answers
  • 47 Answers
SOURCE: Can't get fire on old snowblower TORO 8HP / 32"
te fly wheel is rusted over the magnets remove cover and sand the wheel at the magnets space should be about busnes card thick between the coil and magnets
Posted on Nov 03, 2009
Testimonial: "thanks for the quick answer !"
SOURCE: toro snow master 20 will run and perform well but
Hi
Most common problem is gummed up carb. Have the carb cleaned and i that should take care of your problem.
Sam
Posted on Jan 07, 2010
Testimonial: "Thank you so much as soon as i can i will get it cleaned up thanks for the info i do appreciate it very much."
hunter19_46m
  • 7482 Answers
SOURCE: my toro snowblower stalls out
The loud screech is caused by the starter bearings or solinoid needing lubricant.
Your other problem is the carb...follow these directions and it should solve your snowblower problems
Please rate me
Check your fuel filter in the fuel tank, if you have one.
It may need replacement or cleaning.
Also check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
Posted on Dec 28, 2010
Only runs for a short time
Jeff, Try running with cap off for a short time to see if cap vents plugged, probable dirty carburetor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Snowblower Starts Then Stalls
Tecumseh Carb snowblower cleaning 1 of 2
HOW TO Remove Clean Fixed JET on Snowblower Carburetor
Mar 23, 2016 | Toro 1028OXE Power Max 38663 2-stage...
What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Nov 12, 2015 | Toro Garden
My toro 1028 powermax snowblowers impeller is not spinning. I can move in either direction by hand with no resistance . Is it a belt or a pin? Please help.
It might be a broken shear pin. They are designed to break if an obstruction is hit.
Replace only with original equipment.
Mar 02, 2015 | Toro Garden
New 621E toro snowblower running on prime fuel has been running now will not stay on with choke out what do i need to do
HOW OLD IS THE GAS . PLEASE DRAIN THE GAS OUT OF BLOWER AND PUT FRESH GAS IN IT I WOULD ASLO GET WITH THE STORE THAT YOU BOUGHT IT FROM TO EXCANGE THE BLOWER
Feb 21, 2015 | Toro Snow Blowers. Power Clear 621E 21 in....
Toro snowblower powermax 1028 Starts fine was working well but shifting seemed stiff and after getting stiffer it seemed stuck in low reverse. Any ideas of cause?
Sounds like the Friction wheel is sticking on a rusty shaft.
Stand machine up on it's Chute then take the Bottom cover off.
See how the Friction Wheel should move on the aluminum looking plate. That shaft needs to be clean and slightly greased.
Dec 23, 2013 | Garden
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
I have a toro 421 snowblower i filled it up today with oil and gas when I started it a milky white oil looiking came out the breather tube what could have caused this
it sounds like you had water in the crank case.
Stop running it immediately and drain all the oil. Then make sure the crank case is empty of oil and clean, and refill with fresh oil. After you fill it back up with oil, run it a minute and check again for any milky/foamy oil. If it is clean, check it again after several minutes. If it stays clean, you should be good. If it is milky again, take it for professional service, as you probably have a damaged gasket somewhere.
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
Choke needs to be left on
Carb need to be clean if it set up a a long time
Dec 29, 2009 | Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
32 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
